Overheating
Discussion in 'Technical' started by aubman82, Oct 17, 2010.
  1. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    We recently replaced the 200 I6 with a 302 V8 in out 74 mav. We bought a new radiator for it. It is constantly getting up to 240 degrees when driving. We installed two electric fans, one in the front and one in the back of the radiator. It is still getting up to 240 degrees.
    Any thoughts?
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    What temp thermostat do you have in it, if any? Did you drill the small hole in the thermostat to let the air bleed out? Are you running a shroud? Stock engine or modified? We need more info to help out.
  3. Bryant
    the stock radiator can barely cool a bone stock motor in perfect condition. a fan shroud with a mechanical fan is usually the most amount of air you can pull through the fan. switching to an alum radiator takes care of the problem easly
  4. aubman82
    aubman82 Member
    South Carolina
    1974 Maverick
    We put a 180 degree thermostat in it. Did not drill a hole in the thermostat. Not runnig a shroud, but we have an electric fan in front and an electic fan in back of the radiator. It's a stock 302 from a 1977 Thunderbird. But we added a 4 bbl intake and a 600 cfm 4 bbl carburator.
  5. captainmack
    captainmack Quad Door
    Check your timing ... if it is retarded it will be hot. Is the radiator very clean? If not, and it is a copper radiator, run muriatic acid from home depot through it. make sure the acid only touches iron steel or copper. It will destroy aluminum. I cured a similar problem in my 383 Mopar this way. Take thermostat out. Drained half the water, started the car, poured in a gallon of acid, waited 3 minutes, shut down car. Drain and refill with hose water and run/fush several times.. Runs 167 now on a hot day.
    Make sure you wear protective goggles and gloves, and have a hose standing by.
    I have done this to many engines over the years. On a car engine it is hard to get enough flow going to move the acid around... The stuff they sell at car part stores is a joke.
  6. 74 GRABBER
    74 GRABBER Member
    Peoria AZ
    1974 grabber, 1995 mustang GT, 1967 mustang coupe, 1956 Caddilac sedan Deville
    I would first look at these areas
    Not running a fan shroud of some sort could be the problem all by itself.
    Also what types of electric fans? Alot of the cheap store bought fans don't pull nearly the cfm they state, and also a fan infront and behind radiator could be hurting you to, causing air to fight itself while trying to extract heat.
    IMO your best bet would be to look through the tech archives about a tauras fan setup from a junkyard and also a 130 amp alternator upgrade, or just go back to mechanical clutch type fan and shroud.
    Also when is it overheating?
    At idle?
    City driving?
    Freeway driving?
    What are ambient temps?
  7. blugene
    Is the radiator for the I6 or for a V8?
  8. darren
    I would be looking at radiator condition and the fan set up. If your using the stand alone fans that attach to the rad without a shroud your losing a ton of cooling ability. The only area of the rad that is working well is the area directly under the fans if they dont use shrouds. When your fans turn on check the temp of the air coming off them. It should be nice and hot if the rad is doing its job.
    This is my fan set up with a stock rad 9.5:1 motor and it runs at 195 steady all Summer.
  9. olerodder
    olerodder Member
    NorCal
    Just a couple of observations.........................you should never, repeat never run a fan behind the radiator and then one in front. The one in front is robbing the airflow you need through the radiator..................take it off! I know, a lot of guys put the fan infront of the radiator because of limited room.....................you loose airflow with the fan in front!!!!
    A shroud is needed!
    If you have a fan behind the radiator and with the motor running you should be able to put a dollar bill up against the radiator and have it stick there with the suction the fan is creating.........................if not you need to get shroud or maybe a bigger fan......................IMHO
  10. tomboy
    tomboy Member
    are you using an elec temp sending unit, or mecanical, have you checked the water temp with a thermometer to make sure its really getting that hot?
  11. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    Just a thought, but when I replaced my radiator I ran into overheating problems. "Burping" the system finally remedied the situation:drink:
  12. don graham
    Another small thing to check is the radiator cap. Make sure it is holding pressure.:)
  13. ford84stepside
    Berry Alabama
    That's why I asked about the hole in the T stat. A 1/8" hole drilled in the top of the T stat lets the air find it's way out....
  14. simple man
    simple man Member
    Bunnell,Florida
    Just a thought,did you get a new water pump? If so you may have gotten one for a serpentine belt which is a reverse turn pump. Check your part #s and make sure your pump is a clockwise rotation.:)
