ok dumb question
Discussion in 'Technical' started by todsrods, May 8, 2009.
  1. todsrods
    todsrods Member
    claremore ok
    71 maverick grabber
    I have finally found a maverick :dance:. Going to pick it up on sat. Now the question will a 390 with a c6 fit? Or do I need to change the front suspension? Oh and the car is a 74.
  2. bmcdaniel
    'Nuff time and money you can make anything fit. As it sits now, no. You'll need to get rid of the shock towers.
  3. don graham
    It'll fit if you have enough money. It won't fit unless you change out to an aftermarket or Mustang ll front suspension. :)
  4. todsrods
    todsrods Member
    claremore ok
    71 maverick grabber
    Thanks for the info I plan on doing a complete over haul and was debating on a suspension change. So that helps thank you. I will in the near future be looking for parts I wish to turn it in to a small bumper car. will do pics as I go.
  5. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    390 is a good engine but if I was going to go through all the trouble of a Mustang II front end I would drop a 460 in there. lol
    clitn
  6. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    It'll fit with only a tower shave.
    I wouldn't have believed it myself, but there are pics of the swap right here on the board if you look around. The C6 will be very tight, especially in an early Maverick with the small trans tunnel.
    I just noticed you have a 74 though... Ought to be okay. But there is still plenty of fabbing to do, it's not easy I'd bet, but it's easier than an M2 swap. In which case I would use a 460 myself.
  7. ratio411
    ratio411 Member
    Pensacola
    Here ya go... This is a 74 with 390.
    Looks about like a 351c without a tower shave.
    Hooker and Hedman both used to make swap headers for
    FE Mavericks. The both discontinued them about 10 years
    ago or so. Probably find some used/old stock if you look
    around. They came in tube sizes from 1.875" to 2.25" IIRC.
    The FE exhaust is very much like a Cleveland, as it points
    downward, rather than straight out to the towers, like 302s.
  8. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    Wow that 390 looks cozy sitting in there! Hmmmm....
  9. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    a guy down the street from me has a comet with a 390 4 speed it had the 69-70 front clip welded on in its life ill see if i can get some pics
    brad:)
