Oil Pressure sending unit install with modification
Discussion in 'Technical' started by HarleyGA, Apr 23, 2015.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    FullSizeRender4.jpg Working on installing my oil pressure fittings when I noticed two openings (see pic) . The one in the black section and closest to the oil filter is where I think it needs to go. Right? Wrong? What then is the second opening for? Question 2: I would like to hook up my oil pressure idiot light along with the pressure tubing that goes to the gauge. Does anyone make a prefab connector for this or do I have fabricate one?
  2. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    The plugged hole in the block is for the sender unit. I don't know what the hole in the timing cover is for, I have never seen one like that. I would think you could use both a gauge and idiot light by having a T with both sending units installed.
  3. mojo
    I used a plumbing Tee to setup my light/gauge. I too, don't know what the 2nd hole is for. There is a fitting made for this type of setup; I have one but it was to long to fit where I needed to put it.
  4. 73curtis
    73curtis Member
    ohio
    vdo makes a double electrical sending unit so you can use both gauge and light
