oil pressure line install
Discussion in 'Technical' started by scooper77515, Feb 19, 2007.
  1. scooper77515
    I currently have the clear plastic tubing running to the front of the block, just behind the mechanical fuel pump mounting hole. I have been strongly encouraged to buy braided stainless line with AN fittings, and was recommended to buy a 36" piece. This will be too short to run to the gauge. Is there a closer hole for plugging this into in the block?
    Or will I need to buy 48" and run it back?
    Is it better to go over the valve covers or run it some other way?
  2. Blown 5.0
    MS.
    1974 Maverick
    Mine runs over the shock tower and goes in at or around the steering column, My gauge is under my radio, So i would say get the 48, you can always do something with the slack.
  3. 1slow7t
    1slow7t Member
    Puerto Rico
    70 Maverick, 6 cyl/auto trans, soon to become a 351W w/pan fed C4.
    I've run mechanical oil pressure gauges in the past, but 'm well pleased with the operation of my Autometer Ultralite electrical gauge with it's corresponding sending unit. No tubing or hoses running from the engine to the dash. Just a small gage wire, which is very easy to conceal. JMHO
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    I have mine running along the top of the drivers side valve cover. You could always get the hos and fittings and make it whatever length you want. I believe I used the 48" kit from Autometer.
  5. scooper77515
    OK, if you run from the oil hole right behind the fuel mechanical pump to the hole in the lower dash where the radio was mounted, 48" is about 6" too short.
    I will run a steel elbow facing up, and run a 4" straight pipe up, then connect it there. I am pretty sure it will fit, but will be ugly as hell...
  6. MarulMav
    MarulMav Member
    Bellevue, Nebraska
    1975 Maverick (Grabber Clone)
    I recently replaced my electrical with a mechanical. Purchased the copper tubing from Jegs (which was plenty long enough) and connected to the brass fittings I had in place with the electrical gauge. Prior to hooking it up, I had an extra spark plug wire heat shield (blue in color) and ran the copper tubing through it, doesn't look too tacky. I place a photo but with the local blizzard, things are a liitle hectic.
  7. scooper77515
    I am replacing the plastic tubing for safety and track inspections, and have heard from many that the copper will not pass either. That is why I am going with the braided line.
    Will the 4" straight pipe pass inspection?
  8. don graham
    copper will pass inspection at any nhra track. i've used it for about 7 years now and never had a problem.:)
  9. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    we will get you fixed up
  10. scooper77515
    Does anyone know if there is another hole in the block toward the back of the engine, so I don't have to run the line all over the top?
    I just stuck mine in this hole because the stock dummy light was attached to this one.
  11. NAFORD302
    NAFORD302 Member
    SILEX MO
    that is the only one
  12. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    So run the line along the oil pan. :bananaman
  13. scooper77515
    May try that...might free up a few inches of line...
  14. PaulS
    1/8" copper tubing is cheap! just go get 6 or 8 feet and run your line with some slack so that vibration doesn't break it half way down a quarter mile race track and cause a fire that ruins your car.
  15. blugene
    Go through the fender well, around the door jamb, over the column, over the radio and into the gauge...:D :cheers:
    J/K
    Steel braided all the way...;)
