oil pan removel
Discussion in 'Technical' started by GRABBER/74, Oct 1, 2007.
  1. GRABBER/74
    GRABBER/74 Member
    high ridge missouri
    74 maverick grabber
    hey guys i think i might need to put a new oil pump in my 250 six i was wondering if i need to pull the moter or can i do it in the car just drop the pan i know i have valve trane noise but runs fine the other day i drove it and got back to the house sitting in the driveway at idle in gear the oil light started to flash take out of gear oil light went out? can you help
    thanks grabber/74
  2. RabidCustoms
    you should be able to just drop the pan, I did it several times with the 8 in place,and an extra crossmember the 6 wont have.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Should be able to do it. Worse case you will have to drop the drag link down.
  4. GTwannabe
    GTwannabe Member
    Acworth/Kennesaw, GA
    94 mustang GT, '73 Comet GT 302 toploader 4-speed
    might want to do a rear main seal while your in there.
  5. 74bossmav
    74bossmav Member
    Illinois Machesney Park
    1974 Maverick 2 door Brn.
    Sounds like the oil pump is shot. Light comes on while in gear because that slows the engine speed down just enough to trigger the low oil pressure light. When you take it out of gear it gains enough RPM'S to increase the oil pressure thus turning off the light. Valve train noise is probably not enough oil pressure to keep the lifters pumped up fully which may also mean they are worn too much to work properly even with a new oil pump. IMO you better get that oil pump changed quick.
  6. newtoford
    newtoford Member
    New Castle Delaware
    im changing the one in my 250 soon too
    doesnt look like anything needs to come out but i may need to unbolt the motor mounts and jack the block up a little. no biggie
    i always thought oil pumps tended to have problems at high rpms when they started to go bad, not the reverse. but i guess its possible
  7. 74bossmav
    74bossmav Member
    You will certainly have a lot more damage at high RPM'S if the oil pump is bad because with everything flying around in there at high rev's you need more oil to keep it lubed and prevent damage. I am just saying that a low oil pressure light at very low RPM'S and not at higher RPM'S is a classic sign of an oil pump going bad. Normally the light won't come on at low RPM'S because the pump is capable of maintaining enough pressure . When it's bad the pump is not turning fast enough at low RPM'S to maintain pressure and that triggers the light.
