Oil pan gasket installation tips
Discussion in 'Technical' started by gdemopesq, Jun 17, 2009.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    When I rebuilt my motor and had the engine on the stand it was real easy to install the oil pan gasket. Problem I had one tiny leak. So a few months ago I installed a $40 one piece and my leak was worse.
    I know the basics of tightening the pan bolts across from each other, moving outwards from the center. What should I do to avoid leaks again? I am using the one piece gasket again. Should I use RTV at all? What are your tips?
    Thanks
  2. rthomas771
    I used Permatex #2 to hold the gasket in place. IF there is a next time...I'm gonna use the 4 piece gasket. Did you go back and tighten the bolts again?
  3. 71gold
    when i did the... one piece ...i used set screws to hold it in place.
    i also put sealer in the corner of the front and rear main caps.:tiphat:
    ...Frank...
  4. don graham
    Make sure you don't overtighten the bolts. They only take about 15 pounds of torque. More and you'll squeeze the gaskets out. :)
  5. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    +1 :thumbs2: have not leaked a drop yet, now if I can get that pesky valve cover on my passenger side to quit leaking
  6. baddad457
    You cannot overtighten the one piece gasket, it's got a steel core. You DO need to use the factory pan rail stiffeners with it though. Use these, with the factory bolts and a dab of sealer in the corners of the main caps and you'll have no leaks.
  7. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Rail stiffeners don't look like they would work the old style pan.:huh:
    I thought about doing that myself when I started using one piece gaskets. The pan rail is ribbed on the old pans. The stiffeners are meant for a flat rail. I didn't do it and all my cars are dry that have the one piece gaskets.
    Anyway...
    When you look at the rail of the pan, or any sheet metal cover/pan, you will usually see the bolt holes crowned upward towards the gasket. You have to take a hammer and wood, or flat surface, and knock the bolt holes back to flat with the rest of the pan. Then do not overtighten, or you will bow the bolt holes right back.
    This is a common problem with valve covers, oil pans, tranny pans, etc...
    Flatten the bolt holes, don't overtighten.... = no leaks.
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    I vote for the dimples (cronwned bolt holes) Ratio mentions. That is what caused me a few nights of changing vavle cover gaskets!
  9. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    If you are using the cork style gasket ? If the cork is dry soak in hot water to rehydrate the cork.
    Jay
  10. baddad457
    I used the stiffeners with my front sump pan. No problems there. There are also two separate one piece gaskets for front and rear sump pans (in Felpro) I used the correct one for the pan I'm using.
