Not sure I want to hear it but...
Discussion in 'Technical' started by Bob Wiken, Dec 6, 2009.
  1. Bob Wiken
    Fayetteville, Arkansas
    Let me know your thoughts.
    I had no heat so I was running the car with no rad cap. sure enough some bubbles came out and I had heat again. But the antifreeze was very frothy. I assume that means lots of air in the system but since it had been running for 15 minutes. that froth should have been done. Somewhere, it appears I am getting air into the system. Any place else that could be besides a head gasket? Tell me there is/
  2. mike75mav
    mike75mav Member
    Bremerton, WA
    1975 maverick 4 door; 1971 Bronco frame off restoring
    Sounds like the heater core is blocked its time to replace it. It could also, be the thermosat stuck open.
  3. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    It could have had an air pocket in the heater core and you're still getting the remnants of the air out of it. That's the best case scenario. The worst is just what you're fearing, a blown gasket.
    I would let it run for a while and keep checking it. If it clears up and keeps heat, you're golden. If not, well.... you know what happens then.
    -Scott H.
  4. Bob Wiken
    Thanks Capt. It's time for a bit of a drive tomorrow.. Maybe a compression test too.
  5. Jamie Miles
    Alto, GA
    I've had a few
    Check the oil before and after you drive it again, make sure it dosen't look milky.
  6. Bob Wiken
    Good idea.
  7. Rando76
    Rando76 Member
    Claremore, OK
    Let us know what you find, Bob.
  8. Alan Duke
    Alan Duke Member
    Houston, TX
    1973 Maverick
    I got a kit from NAPA that you put over the open radiator neck with a purple liquid in it. (Looks a little like a turkey baster) You pump it a couple of times and the one way valve sucks the fumes from the radiator. If the liquid changes color, you have a blown head gasket. I'll try and get the PN on it later. I think they rent them to.
  9. Bryant
    on my car i put a flushing tee in the heater hose at the highest point.when i fill the motor i leave the cap off till coolant comes out. this seems to really help with keeping air out of the system and is a cheap thing to do.
  10. Bob Wiken
    I took it for a short drive today. The oil is not cloudy or foamy before or after. (that's good). I did have heat after the thermostat opened.(that's good). There was no foam in the coolant. (That's good) After I put the cap back on, there was a little foam but it wasn't frothing out the neck like yesterday. (that's good but inconclusive). I guess i'll just drive it and keep an eagle eye on it. Thanks for the help.
  11. don graham
    Just a thought bob. Have you tested the radiator cap. It may not be sealing or holding pressure. There is a test kit for doing that. Or if it's an old cap, there cheap.:)
  12. apotter80
    apotter80 Member
    charlotte, MI
    1971 maverick grabber(CLONE)
    had the same problem and it was a bad cap. i run a 13 pound cap... i think...maybe a 16? Anyhow i would change it. they are cheap.
  13. Bob Wiken
    It's a new cap. It's been too cold here to do anything. When we get a warm spell, I'll get back to it.
  14. baddad457
    The foam might be due to the type of water you used. Doesn't sound to me like you've got any problems here.
  15. Bob Wiken
    Baddad, I hope you're right
