Not lovin' the trim.....
Discussion in 'General Maverick/Comet' started by sabrina, Dec 2, 2007.
  1. sabrina
    sabrina EyeNurse
    Roanoke, VA
    1975 Maverick "Frankie"
    Hey, guys. I would like advice. My car has this metal trim on the sides that I am not all that crazy about. When the time comes for paint, what do you use to fill the holes where the trim was attached? (something that will not sink in later) I have seen holes that were filled, and then after it was painted, the filler sinks in and causes the hole to show / paint to crack / rust, etc. What are your thoughts? I think they just look better without that metal trim. ;)
  2. maverick75
    Weld them shut..If you dont have access to a welder try POR epoxy i've seen great results with that....:bouncy:
  3. newtoford
    newtoford Member
    New Castle Delaware
    yea ive got a simular issuer to address
  4. sabrina
    sabrina EyeNurse
    Roanoke, VA
    So you weld then sand flat?
    Hey, NewtoFord--what are you planning to do? Are you going to weld?
  5. newtoford
    newtoford Member
    New Castle Delaware
    hopefully. i dont have one nor do i know how to and everyone i talk to with welders and expierence is afraid the metal is to thin and they'll burn right through. the hot knife through butter affect i guess. same people have been telling me "no way" to a patch panel to the bottom of my front fender for the same reasons
    im really OCD when it comes to filling holes in metal with non-metal fillers...
  6. monster 302
    monster 302 Member
    Meridianville,Alabama
    1976 ford maverick
    the body shop did it to mine and saind theay had no problems while doing it.
  7. newtoford
    newtoford Member
    New Castle Delaware
    yea i know its possible. guess the guys i know just dont have the skillz lol
  8. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i welded mine close. then grind flat,filler if needed,prime and paint. thats it in a nutshell
  9. 71gold
    these are trim holes...
    Hole...countersink and ping
    por 15...filler
    sand and primer...:thumbs2:
    ...:Handshake...
  10. Mavaholic
    Welding is the only way to go.
    Your only 90 miles up the road from me.
  11. newtoford
    newtoford Member
    New Castle Delaware
    yea i guess i'll have to look you up sometime
    since i got new doors and drivers side fender to ut on the only places left with trim holes would be the rear 1/4s and pass. fender
  12. Jean Doll
    Palmerton, PA
    Welding the holes shut is the only permanent way to do away with them.
    Fan2488's description of the process is right on the money.
  13. blugene
    I would drive that just to meet you... the welding would be the bonus. (y)
  14. Sam M.
    Sam M. Just a nobody
    Southern NJ
    I got mad skillz, yo! Looks like you're getting plenty of offers of help, so I might as well throw my hat in the ring too. About a half hour drive for you. Got a heated shop and plenty of beer in the fridge (ok, beers come after welding). I'll zip em shut for you and you can follow behind on the grinder.
  15. newtoford
    newtoford Member
    New Castle Delaware
    haha thanks man. maybe when it gets a little warmer out i'll come up. i need the bottom of my pass. fender patched up too. is that something your qualified for?
