Noisy Alternator
Discussion in 'Technical' started by Mars, Oct 6, 2012.
  1. Mars
    Mars Member
    Leiden, the Netherlands
    Ford Maverick 1972 - 4 Door Sedan
    Hi All,
    i got a 1972 4 door Mav and looking at replacing the alternator as it got became quite noisy, probably worn bearings? i been trying to find a replacement part but not sure what to order...the only really clear mark i could find on the alternator is "60A" which must stand for 60 Ampere, but when i look for an alternator for my type car on autokrafters i only find 75A or 90A alternators. Can someone advise me on this? just i case i took a picture of the alternator.
    THANKS! :)
  2. captainmack
    captainmack Quad Door
    I have the same car.. I will look for you, so you don't have to make long distance calls to America! give me a day, I'll get back to you.
  3. Krazy Comet
    Those alts are fairly easy to service, I've usually just overhauled my own... Front bearing is a 6203 and is common as parking lot gravel, Snapper even used then in the pulleys of the drive system on their mowers... I can't remember ever needing to replace the rear bearing, usually with front bearing and brushes they're good for another 100K mi...
  4. Mars
    Mars Member
    Thanks for the replies :) and for the link! i wasn't familiar with rockauto, comes up with a lot more specific results then on autokrafters.
    So i see, for my car, 1972 FORD MAVERICK 5.0L 302cid V8, i get a couple of different alternators to choose from? any of these better then the others?
    Or should i just get the bearings and brushes as Krazy Comet suggested. it would probably be a bit cheaper but not sure if would i need any specials tools to replace it.
    Thanks for your advice so far!
  5. baddad457
    He's in the Netherlands, they may not have gravel there :hmmm:
  6. baddad457
    You can use the bigger alternators, but I'd suggest replacing the fusible link between the alternator and the battery when you do so. Wouldn't be a bad idea to replace that anyway, mine popped and I "played hell" in trying to figure out why it wouldn't charge the battery.
  7. rthomas771
    Being you having an early alternator case...don't return it as a core. Mustang guys will need that style case for their resto. Early alternator case w/round shoulder in foreground...rebuilt case in background. Who knows...you might make an exta dollar or two.
  8. Mars
    Mars Member
    Ahh okay so the "core" price is when i would send back my part and then i get a refurbished part back? Don't think that would be a good option for me anyway as i probably order the part from the US, i don't want to have to send it to the US first before getting my replacement part.
    So if i get it right, i can get any alternator that is on the autokrafters site, but also taking advice to replace the fusible link and battery, and you think that i can then even sell my old alternator for a couple bucks? repaired or not?
  9. baddad457
    Yes, you are correct.(y) The core charge on alternators isn't what you'd call a "deal breaker"
  10. rthomas771
    I haven't checked the price but wouldn't an alternator be cheaper at any parts store than buying from Auto Krafters? Gotta remember they will be a shipping charge. The 75 amp alternator is the same physical size as the 60 amp and will swap out with no problem.
  11. Mars
    Mars Member
    I know a couple of places that i can try here in the netherlands, but Comet Fever also pointed me to rockauto, i will have to compare what would be cheaper :)
  12. Mars
    Mars Member
    I didnt even know about the core charge before you mentioned it, i saw it on the site, but had no idea it worked like that :)
  13. Mars
    Mars Member
    well i found a couple of places that have ford usa alternators, but none that seems to be specific for maverick or mustang, and none of 60A. but the ones that i did found were in the price range of 90 - 260 Euro so like between 120 and 325 dollars :p
    on Rock Auto i found one 60A Acdelco Part#3342099 for €33.99 plus Fedex Internation Economy €53.78 is a total of 87.77 euro
    so far it seems to be cheaper to order from the US! :)
  14. Dave B
    Since your in Holland, I'd check RockAuto's shipping, it's outrageous to Canada, and we're right next door, I wouldn't want to think what it would be to Holland. There has to be a Mustang parts seller somewhere.
  15. Mars
    Mars Member
    on RockAuto: 60A Acdelco Part#3342099 for €33.99 plus Fedex Internation Economy €53.78 is a total of 87.77 euro
    so far the cheapest alternator i found here in the Netherlands in a webshop is 90 euro, but i also requested a quote from USA Car Part dealership, but so far RockAuto would be the cheaper option, although i will have to see what the deal is exactly with the import tax, but i believe as long as its under 160 euro there should be no additional tax.
