New "strut rod bearings" offered for our cars!
Discussion in 'General Maverick/Comet' started by CometGT1974, Nov 16, 2004.
  1. CometGT1974
    CometGT1974 Gearhead
    Western NC
    74 Comet GT
    I've had these on the car for several months now but wasn't supposed to tell anyone since they were still in the R&D phase. Now they are available to the public and I just wanted to let everyone know about them. They replace the stock strut rod bushing with a spherical aircraft bearing. These will work best for drag racers or road racers but do have some benefits for the everyday driver. Let me know if you are interested and I will get you the information you need to get a set. I think asking price will be around $250 - $350 for the set. Not cheap but high performance never has been!!
    It's hard to see in the pics but they say "CALVERT RACING" on them as they were designed by the same people that make Cal Trac bars.
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Stephen,
    I'm not sure that I understand the benefits.
    Is there still circulatory movement of the rod
    without any front to back movement? It seems
    like there would be some leverage type movement,
    I guess it allows for that.
    Seth
  3. CometGT1974
    Western NC
    74 Comet GT
    This allows for free movement of the front suspension with NO resistance. With the rubber bushings there is ALOT of resistance to allow the suspension to do what it's supposed to do. The shock/spring is supposed to dictate the movement of the suspension, not the bushings. This is just one part of the whole puzzle and is one of the reasons my car transfers weight so good. The spherical bearing is "sandwiched" between the aluminum plates, the bearing allows for free up and down movement with ZERO front to rear deflection under hard braking or when the front tires touch back down, exactly what you want for a road race car or drag car.
  4. CometGT1974
    Western NC
    74 Comet GT
    No more rubber bushings! Remember, you probably won't see much benefit from these on a daily driver or a show car.
    Trust me, Calvert Racing or I wouldn't put the time and effort into them if they didn't have some benefits. I sure as heck wouldn't have gone without one of my strut rods for 6 months if I didn't think it wouldn't be worth it for my car. I assisted on most of the R&D work for our cars! They were on the car at the Roundup but nobody noticed!!
    As I stated, these are not for everyone but there are some people out there that will appreciate there benefits. I'm one of them!:D
    PS- Lots of thanks to Moneymaker Racing for allowing me to work with them and Calvert Racing on getting these out to the public!!
  5. littleredtoy
    littleredtoy Seth
    '74 Comet GT
    I get it now.
    Perhaps that is why my front end seems so much stiffer now with the
    polygraphite bushings up front. It's really tight, although not as tight
    as yours would be.
    Seth
  6. CometGT1974
    Western NC
    74 Comet GT
    But what does it do under VERY hard braking? The bushing, no matter what material it is made out of "gives". This "give" is very undesireable in a road race car. But rubber, polyurethane, polygraphite and the like are just fine for a daily driver. These are for those racers that are looking for every last advantage. The same principles apply for the upper and lower control arm bushings.
  7. RabidCustoms
    those look like the same offering as total control products.
  8. CometGT1974
    Western NC
    74 Comet GT
    As far as I know TCP doesn't offer ones that will work with our cars. The early Mustang style will not work.
  9. FoMoDave
    FoMoDave Maverick Owner
    Cumming Ga.
    1973 Maverick 302 c-4,1971 Maverick 6cyl
    Auto krafters offers them for $245. They are by RSS
  10. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Those look well made :) It seems as tho someone else has a set up like that...
    Ivy Collins maybe?
  11. CometGT1974
    Western NC
    74 Comet GT
    RRS doesn't offer them for Mavericks yet. These are application specific.
  12. CometGT1974
    Western NC
    74 Comet GT
    Ivy does have something similar to this but I don't think his uses the stock strut rod. Some classes require the use of a stock "unmodified" strut rod.
  13. Gent
    Gent Member
    virginia
    72 grabber
    thanks for the info.
    Let us know if your 60 foot times get better.
  14. CometGT1974
    Western NC
    74 Comet GT
    Just putting these on your car WILL NOT have a major effect on 60' times. Like I said in a previous post, this is just a small piece to the big puzzle. The combination of ALL the "trick" things i've done to the suspension is what has dropped my 60' time.
  15. M.A.V.
    Macon,Georgia
    Oh , I did`nt realize that the Calvert racing peices retained the stock strut rods. Do you have to drill holes for the bolts I see to go thru the frame ,, or do they just "Sandwich" the frame between two halves useing the two large stock bushing holes?(it looks that way)
