New Rear End
Discussion in 'Technical' started by jreckel, Sep 13, 2005.
  1. jreckel
    jreckel New Member
    Olathe, Kansas
    I'm thinking of changing my stock 300 4 lug rear end to a 355 posi 5 lug. My question is will I have to replace the drive shaft or will it bolt up to the u-joint housing on the new rear end. The width is the same on both, 52 inches so it should fit under the car ok. Its going in a 71 mav.
    JR
  2. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    If both rearends are 8-inch, you do not have to change the drive shaft. It's a direct bolt-on...
