New Member saying HELLO from West Covina,California
Discussion in 'New Members Forum' started by steve lieras, Oct 23, 2008.
  1. steve lieras
    steve lieras New Member
    west covina,, california
    74 maverick, 63 ranchero
    :chirp:I got a 74 maverick,, with a mild cam,ported heads,edelbrock intake & carb, and hooker headers with flowmasters,, and a stock raditator,, but the problem i'm having is that it starts to heat up,,i have a electric fan with home made schroud,, but it still seems to heat up ,, any sugestions !! Thank's :bowdown:
  2. CaptainComet
    Welcome!
    Lots of great Mavs and Comets and owners here ... very friendly board.
    Overheating ... is it doing it in traffic and/or idling? ... or out on the road at speed? ... do you have a temp guage? ... if so, what temps are you hitting?
  3. don graham
    Welcome to the board. Was the car originally a 6? When was the last time the radiator was cleaned out? Has the block been bored out? Is this something that just started? :Welcome:
  4. JAMEYH72COMET
    JAMEYH72COMET Member
    elizabethton
    72 comet,2003 convertable gt mustang, 71 ford f100.
    Great place for info
    (y)Every one on this board is a big help you will like all the info.
  5. Mercurycruizers
    Venetia, PA
    :Welcome:to the board....
  6. Comet155
    Comet155 Member
    Welcome Steve.
    The stock 3 core is barely adequate (the stock 2 core will quickly be overwhelmed by a v8).
    The factory monster 7 blade flex fan and shroud set up for the AC option does move a massive amount of air.
    If you insist on keeping the electric fan...you might have to consider a radiator upgrade.
  7. steve lieras
    Overheating,,
    :mad: It overheats in traffic and at speeds on freeway and im hitting temps from 190 to 220, it is a V-8 car , when i bough the car, the fan shroud was broken,so i put a flex fan on it with a junk-yard shroud not meant to fit a maverick,, but it worked untill i had it rebuilt, thats when i made a steel shroud for a electric fan,, and it still runs hot,:cold:, will i have to upgrade my radator,,what kind of inexpensive up grades are out there, !!!:thumbs2:
  8. Comet155
    Comet155 Member
    You could try a couple cans of 40 Below (by Pro-Blend) as a band aid, but it sounds like a new aluminum rad may be in order.
  9. Mavaholic
    What kind of compression are you running? Have you tried running hi-test gasoline?
  10. rayzorsharp
    Welcome aboard! Nice looking car you got there. (y)
    I highly recommend an aluminum radiator. You can buy a direct fit for around $250...and they look great!
  11. steve lieras
    overheating,,
    (y)I think i'm going to look into a aluminum radiator,, that way i have no worries,, and problem solved,, thanks guys,, :clap:
  12. rayzorsharp
