New Carburetor
Discussion in 'General Maverick/Comet' started by b717doc, Mar 17, 2011.
  1. b717doc
    b717doc Member
    Hiram Georgia
    1974 Ford Maverick
    Ok. so we got a new carb. for my maverick's inline 6 cyl. engine. It's got an electrical choke... uhm... SOS!!! What does it hook to? Help?:huh:
  2. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    1976 ford maverick 302v8
    What year? I know on my 76" that you splice the electric choke lead in on the white/black wire (terminal S) between alternator and the voltage regulator... not sure about your year, if the colors would even line up, or if that would be correct on ALL years.
    check http://www.1bad6t.com/Maverick/repair/chassis_electrical_05.html
    for wiring diagrams, to see where it should wire in.
    Supposed to run a fuseable link between the choke and that connection i believe... i think we just popped a 30 amp in line fuse to mine.
  3. mean_maverick
    ^^--what he said
  4. b717doc
    b717doc Member
    Hiram Georgia
    1974 Ford Maverick
    it's a 1974...
  5. Cowboiup1979
    Cowboiup1979 Member
    Louisville Kentucky
    74, as far as THAT wiring is identical to mine, like i said, tap it in the "s" terminal on the alt, run either in-line fuse (best option imo) or a fusable link between it, and your electric choke.
