neutral safety switch location
Discussion in 'Technical' started by 1970mavinator, Mar 8, 2009.
  1. 1970mavinator
    1970mavinator Member
    Ruskin, FL
    1970 2dr I6 maverick
    I need to know the location of the switch and the color wires that go to it. Thank you
  2. 71gold
    column or floorshift...
    Dave Boyer helped me with mine...:thumbs2:
    ...Frank...:yup:
  3. Deanbeard65
    Deanbeard65 Member
    Tucson, Arizona
    1976 Maverick 2DR 302
    it will only be two wires check this out like you were told under the dash if it has a column shifter. On the floor if it is on the floor. Someone who owns a 1970 might know if the color changed.
  4. 1970mavinator
    Ruskin, FL
    column shift, sorry. Automatic trans if that matters.
  5. PaulS
    The switch is located at the base of the column. A rod from the key switch runs dowb the column to activate it.
  6. Dave B
    Shhh!!, don't tell everyone!!
