need help!!!!!
Discussion in 'New Members Forum' started by myfirstgrabber, May 3, 2014.
  1. myfirstgrabber
    myfirstgrabber New Member
    Yakima, wa
    75maverick grabber
    I have 2 87 5.0 truck moters 1 is already setup to v belt the other im building I also have a 76 mustang 2 c4 and my original 3sp manual out of my 75 grabber was told neither moter will work with my stock part from either tranny
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    You will need a flexplate or flywheel with the newer 50oz. balance weight as opposed to the older 28oz. of the 70's.
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    :Welcome:to the site!!!!!
  4. Red1972Grabber
    Northern California
    Welcome from Northern California!:chirp:
  5. SlotlessMan
    SlotlessMan A squirrel and his nut
    Chetek, WI
    71 Grabber
    Welcome!:tiphat:
  6. 71gold
    :Welcome:...:Handshake
  7. schroensr
    Berkeley Springs,WV 25411
    1975 Mercury Comet
    Welcome to the forum. :Welcome:
  8. Krazy Comet
    :yup:...
    The larger 157 & 164 tooth C4 flexplates are readily available in 50oz but I dunno about for the M-II trans... I believe that one is like 148 tooth...
    Also there is no boss on lower left of 5.0 engine for clutch or column automatic linkage...
    If you have a roller cam then you need a steel dist gear as the std cams use a iron gear... Stock cams in '87 truck motors are iron though, block is roller cam compatible...
  9. mav1970
