need help
Discussion in 'General Maverick/Comet' started by Shades, Mar 10, 2010.
  1. Shades
    Shades Member
    Bay Area
    1972 maverick
    i recently put in front disc brakes on my maverick but now i have a 5 lug in the front and 4 lug in the back and now i have no idea wat to do for rims. any input would be a great help. thank you
  2. Bryant
    there lots of styles of wheels that are offered in 4 or 5 lug versions. you could get two of each if you find a style you like. i would sugest looking for a 5 lug diff to put in the rear. that would be the best way to take care of it.
  3. Shades
    Shades Member
    Bay Area
    1972 maverick
    i wish i could but dont have funds or knowledge to pull that off
  4. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    one from a later model maverick would bolt right in
  5. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
  6. 302-72-mav
    302-72-mav Member
    sactown CA
    he has a 72 so it must be a 8'' cant he just swap the axles out with 5 lug
  7. Cpt. Bondo
    Cpt. Bondo Member
    Summerville, South Carolina
    (2) '72 Comet GTs, 68 Mustang
    I would honestly get a later model 5 lug rear axle and swap it out. If you did the front swap, you can definitely swap out the rear axle! It's an easier job than the front brake swap. You'll also get bigger (and better) brakes with the swap.
    They're not that expensive and you'll have matching rims at all 4 corners. As it sits now, you'll have to carry 2 spare tires around at all times or hope you never get a flat tire.
    I'm not sure if they will fit :huh:, but if they do he would still have to swap over to the bigger brakes due to the difference in the drum sizes between the two. It would be much easier to swap the whole axle than swapping over the axle shafts, backing plates, brake hardware, etc.
    Hope this helps,
    -Scott H.
  8. 71gold
    NOPE!!! :Handshake
  9. Bryant
    the 4 lug 8"s have a smaller housing end and use a smaller axle bearing. the brake offset is shorter on the 4 lugs also. all that makes it not doable.
  10. Shades
    Shades Member
    Bay Area
    1972 maverick
    thnks guys for your input ill see what i could find, but what other diffs could be put on a 72 mav becuz all the mavs that show up around here get picked to the bone pretty quick
