Need help with heater core.
Discussion in 'Technical' started by Chenny94, Jan 11, 2014.
  1. Chenny94
    Chenny94 Member
    1974 Maverick
    I got to get the old one out. I've got all of the dash removed around the glove box. And I've pulled the fiberglass box out enough so I see the old heater core, but I can't get those clamps around the hoses off. They got slots for a flat head screwdriver, but one I know I won't be able to reach with the screwdriver. What tool should I use? Sizes, tool, etc.
  2. rthomas771
    Get under the hood and remove 4 nuts to pull the box out of the car where you can work on it
  3. Dave B
    5/16" socket should fit on the hose clamps, use a long extension and a swivel.
  4. 71gold
    can you cut the hoses under the hood, pull out the box. replace them with new ones, stick them through the firewall when you reinstall the box.
  5. m in sc
    m in sc Member
    rock hill sc
    exactly. or if they are new-ish, take them off the motor and pull the hoses through the firewall with the box. its a biach but thats how you do it.
  6. rthomas771
    This is how I do it. Once the box is out of the car...take the hoses off the core. This also keeps the carpet from getting wet
  7. Chenny94
    Chenny94 Member
    1974 Maverick
    ive got the bolts undone, i just need to know how to pull the box out. it wont budge.
  8. 71gold
    you missed a bolt somewhere...:yup:
    as Jeff suggested...Get under the hood and remove 4 nuts.
  9. rthomas771
    There is a bolt also under the dash on the bracket...top right.
  10. m in sc
    m in sc Member
    rock hill sc
    yup. on a metal bracket, head of bolt aims straight down. close to that metal bar that holds the lower part of the dash tray in.
