need help to id rear end
Discussion in 'General Maverick/Comet' started by nastynickel, Apr 22, 2008.
  1. nastynickel
    nastynickel gearhead car junkie
    Portorchard, WA
    1972 grabber mav
    Ok I found a 79 monarch at the local pull a part, problem is they came with an 8" and a 9". The gal on the phone dont know what it is, and they look the same. What is a sure fire way to tell the differance between the two?:huh:
  2. Mavman72
    On a nine inch you cant put a socket on the bottom nut under the pinion housing.On an 8 inch you can use a socket on all the carrier nuts.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
  4. nastynickel
    Portorchard, WA
    1972 grabber mav
    Thanks guys for the info! I just went out to the shop and looked under the mav at the 8" and then went to a buddys shop to look at a 9" centersection, I now know what you guys meant by the socket test. I know you senior members must get tired of repeating your selfs all the time but this FNG appreaciates your patience. Wish me luck as the pull a part yard said if it was a 9" I could have it for $125, I'll let ya know how it turns out. I'm outa here :burnout:
  5. don graham
    Good luck. Another quick way is that the 8" has that little hood over the top sticking out the front.:)
