need help/351windsor will it fit /74comet
Discussion in 'Parts Interchange' started by robertcomet, Jul 3, 2006.
  1. robertcomet
    robertcomet New Member
    carman/MB
    74comet
    i could use some help/info have a 74 comet with a 250/6 .got a good deal on a 351 windsor /tranny out of ford f150 will it fit in my comet will i need to modifiy anything should i buy it?or is there to much work ?some say yes ,some say no can anyone help out ?send me a pm DON"T KNOW WHAT TO DO .would love the power,it has 75000 kms on the motor.....thanks rob!
  2. johnson
    johnson Member
    fargo, ok
    69.5 maverick
    dont know on that. im going to use a mustang 2 front end that should make it easier on me with a c4 tranny
  3. maverick75
    a W will fit but its much easier to change plugs if you shave the shock towers a M requires alot of modification
    for more info go to
    http://mmb.maverick.to/search.php?searchid=285085
  4. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    What year 351w?
    What exact model tranny?
    The year of the engine is not really important, I am just curious.
    The model of tranny is important. A C4 is going to be the only 'good' fit.
    What year F150?
    No matter what year, the oil pan would likely not fit.
    As posted above... if you know it is a 351w, then it will go in with only the modifications needed to your car to take in a 302.
    Swap headers are recommended. I have seen unshaved towers and stock manifolds used, but wouldn't know what the manifolds came off of (certainly not a truck) or if they needed modding.
    A 351w uses all the same mounts, tranny parts, starter, pulleys, etc that a 302 uses. So the swap is fairly easy.
    Good luck
    Dave
  5. robertcomet
    carman/MB
    74comet
    351
    well i think im going to buy it ,also comes with 4 center lines /tires he want 400can i will give him 350 and take it ........wish me luck :drive:do you guys think that with it in it will go pretty good?
  6. bartikus
    bartikus Member
    salt lake city, ut
    dude i have no problem smoking tires in my car. i even have and open rear end with 2.79 gears and a strait six manual trans. so i imagine that there will be no tires left on your rims when you are done.:rofl2:
  7. fastbackchaseca
    fastbackchaseca Lead Troublemaker
    Los Angeles
    '72 Comet, '56 F-100, and "88-0232"
    i have the "exhibition of speed" ticket that can vouch for that 6cyl/3spd/2.79 gears burnout
  8. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Lol :rofl2:
    My mav doesnt really like to go and it REALLY doesnt like to stop. It couldnt burn one tire if it was sitting in a puddle of oil.
  9. fastbackchaseca
    Los Angeles
    maybe it's those extra 2 doors that are holding you back...:huh:
  10. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    We will see how it likes my 393.
  11. fastbackchaseca
    Los Angeles
    i wanna see how my 2 door runs with 158 more cubes, 2 more gears, and a 3.73 locker out back...
  12. don graham
    351 w will fit. i had one in my 71 grabber. same motor mounts. need to be on a c-4 tranny or you'll have to make some mods. unless i were going to shave the shock towers i would stay with a 302 and maybe stroke to a 331 or 347.:)
  13. fastbackchaseca
    Los Angeles
    i was shooting for a 408w and a g-force t5. notch the towers and do a cable clutch setup. hardest part should be the same as most people's... headers... if anyone has a junk set of sbf headers laying around, im interested in them as long as the flange and the upper few inches of the primaries is good, since it looks like im going to be making my own
