need help/200ci-302v8 engine swap
Discussion in 'Technical' started by MAVERICKMAXX07, Aug 4, 2008.
  1. MAVERICKMAXX07
    MAVERICKMAXX07 New Member
    FLORIDA
    73' MAVERICK 2DR,W/351W
    I AM PULLING MY 6CYL.,OUT TO DROP IN A 302V8. I WANT TO START THE ENGINE,BEFORE I PUT IT IN.I DON'T KNOW HOW TO WIRE IT UP,TEMPORARILY TO GET IT STARTED.
    IT'S GOING IN A 73'MAVERICK,I DRIVE IT DAILY TO WORK,SO I NEED TO MAKE SURE THE ENGINE IS IN GOOD SHAPE....FOR A QUICK SWAP!
    ANY HELP WILL BE GREATLY APPRECIATED, THANKS CARL MAXX:bouncy:
  2. PaulS
    You will want a rack of some kind to set the engine in, You need a battery, ignition resistor, on-off switch for ignition, push button start switch, solenoid, starter and cables. You will want a can of gas and a hose to connect it to your pump. Make sure you have some kind of throttle control and a return to close spring.
  3. Bryant
    this remindes me of another post on here a while back about how people would start the motor on the ground and it would go rolling away. that was funny stuff.
