Need Addvice
Discussion in 'Technical' started by BigDog41364, Jul 10, 2012.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    My motor is running rough at higher rpm,s (2000-4500ish). When its in neutral it runs good, it misses a little but when there is a load on it (driving it) it runs a lot rougher. you can hear a misfire and feel a bad vibration. im thinking vacuum advance is not working correctly but i don,t know how to check it. any other suggestions or advice would be greatly appreciated.
    Motor Info
    302 .060 over
    KB Pistons 10.7to1 Compression
    Comp Cam Big Muther Thumper Cam .491 .476 Lift 107 deg
    Comp Cam Lifters, Push Rods, Magnum Steel Roller Rocker Arms
    Prostar Aluminum heads
    Weiand Stealth Intake
    Holley Street Avenger 670cfm Vacuum Secondary
    GM Style HE Distributor
    2Hrs of run time on fresh rebuild
    On a side note. this forum has been fantastic, you guys have been great and have a vast knowledge on mavericks,always polite and have helped us out immensely. hopefully we can get this running so we can get to the roundup and put some faces to the names
  2. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    Its a flat tappet engine, right? Any lifter noise? Hope the cam break in went well.
  3. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Yes flat hydraulic lifters, i used the comp cam's break in additive and followed the break in procedure. im going to pull the valve covers today and check things out, see if there is something noticeably wrong, i don't here anything but im going to check anyway
  4. groberts101
    groberts101 Member
    Minneapolis, MN
    disconnect the vaccum pot completely..plug the hose.. and see what it does.
    You may have the carb misadjusted and/or the ignition advance curve may be such that it's causing a lean misfire. Adding advance from the pot may just be adding insult to injury at this point.
    What is the initial advance set to right now?
    Does that carb(new or used?) have power vavlve blowout protection built in?
  5. Mavman72
    Check your valve train adjustments and valve springs...Take a good look at your pushrods too...
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    I always go so far as to pull lifters and check out the current mating between the cam/lifter lobe just to be sure as well. Even the slightest galling now.. can rear its ugly head many hundreds of miles later on when you are floating on the cloud of success. Metal flakes in the oil can wipe the whole motor and make you wish you had double checked surface run in.
    Even just thinking about this stuff makes me happy I only run full rollers on everything these days. :burnout:
  7. Blown74
    Blown74 Member
    Va
    74 302 blown- 68 Shelby Gt 500- 69 Cougar XR7 428 ram air
    vibration/miss
    Valvetrain X2...check everything, sounds like a bad lifter to me:cry:
  8. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    well ill have to continue the diagnosis in a day ou two, I was driving it to the alignment shop,after about 10 mi. the fuel pump died, its been acting up for a few days,now im thinking low fule pressure might be the culprit...LOL
