mustang sway bar v.s maverick sway bar
Discussion in 'Technical' started by Joe Dirt, Feb 10, 2010.
  1. Joe Dirt
    I figure some might find this helpful this is a stock 11/16 maverick bar and a 64-66 mustang 1" addco bar.
    And YES it fits.It should fit a stock height or 1-2" drop with the mustang end links supplied. My car is 24" to the fender lip and i had to play with the end link height (used my maverick bolts instead of the mustang ones theres about 3/4" height diff between the two ) to get it were i wanted it at bar "level" at rest.
    bar part number 536
    http://www.summitracing.com/parts/ACO-536/
    Now to decide on a rear bar diameter :rofl2:
  2. Dave B
    Sweet! I was hoping you'd have pictures!!
  3. Joe Dirt
    As always I try to,I do however kinda wish i went ahead and got the 1-1/4 bar now :rofl:
  4. Mercury-beast
    Mercury-beast Member
    cali
    1975 ford maverick in process of having a 89 roller
    woaa haha nice car, what did the mustang sway bar do for you?
  5. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i always wondered if one of those would fit.
  6. Joe Dirt
    reduced body roll,improved cornering grip
  7. PaulS
    The rear bar diameter should be about 2/3 of the front bar with the weight distribution on our cars for the same "neutral" handling characteristics. It the rear bar is as big as the front bar you are likely to encounter "oversteer" (the back end wants to get ahead of the front on turns). If it is too small then you will have "understeer" ( the front end wants to keep going straight in the turns). The driver and his habits have a great deal to do with how severe each situation is in actual operation.
  8. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    the question is are there any rears that fit?
  9. Dave B
    Well, after 2 years, I finally have a 1" 64-66 Mustang sway bar...I'll install it tomorrow.
  10. Resto
    Resto Benders Evil Twin
    Yuma AZ
    What Rear Bar did Mashori put on His?
  11. groberts101
    groberts101 Member
    Minneapolis, MN
    haven't been here long enough to see this thread yet.. but I too would definately be interested in knowing who interchanged what product from what model into these cars.
  12. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    He put the Addco 3/4" maverick kit on the back of his car. Unfortunitely they have a problem with cracking out the frame section.
    Mashori had to fix his because it cracked.. and I noticed that mine is cracked on the passenger side so here in a week or two I get too pull mine off and put some reinforcing plates on mine too.:cry:
    mmb.maverick.to/showthread.php?t=70939
  13. Resto
    Yuma AZ
    Hmmm Proly gonna do the same. Unless I can find a torquion bar system to adapt.
  14. Dave B
    Do you think a rear sway bar really makes that much of a difference on these cars? I was talking to someone with a 68 Mustang, he put one on his car, and he said ,it made it feel twitchy.:hmmm:
  15. Resto
    Yuma AZ
    Well Bro Im gonna play safe. With the kinda power Im sending back there Im gonna need some stabilization when things get squirly.:drive:
