MSD Blaster 2 Coil
Discussion in 'Technical' started by NJShoreMav73, Apr 30, 2005.
  1. NJShoreMav73
    NJShoreMav73 Member
    Central, NJ
    73 Maverick- 2 Door, LDO Trim, 302, Bucket Seats, Automatic on the floor.
    I got my engine back together....mounted the radiator, filled it, and tried to start it. No luck.
    I checked for spark and it was very weak. I went out and bought a new MSD coil. The instructions say that with a stock distributor with points (which is what I have) you must use a ballast resistor inline with the positive wire on the coil.
    Is this necessary? If so, what is the purpose?
  2. Maverick Man
    California
    yes i belive you should..
    if you were running a MSD dist you wouldn't need it.
    the ballast is to regualte it so you don't burn the points out. however even older mallory unilights still say you should run a ballast resistor. :huh: i'd run it.
  3. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The ballast resistor drops the voltage down to the coil. Like Derrick said without it you will burn up the points.
  4. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I used the original factory wire to power my Duraspark Coil in my 74 when I switched from points ... is this something I should be concerned with?
  5. maverick1970
    Missouri
  6. Pegasus
    Pegasus Powder Coating Nut
    Channelview, Texas
    '76 Maverick 2 door 302 V8
    NJ, I'm also running the Blaster 2 coil, 6A (not AL) box and the MSD Distributor. I don't use a ballast resistor on my CHP V8 since the MSD distributor handles it. I'd go that route if you could since points are hard to set and very unreliable. My son still gets a kick out of pulling off the coil wire and watching the MSD spark jump from the coil (by the water bottle) clear to the shock tower support! (about 1 foot!). I stuck my finger in the area once and I promise I'll never do it again!
    Go all MSD, you can't go wrong ;)
  7. dmhines
    Cumming, GA
    The original points setup had a red wire going to the coil from the wiring harness and a black wire going from the coil to the dizzy. The Duraspark setup now has a Green wire going to the coil from the Duraspark box and I reused the original red wire from the factory harness to the coil ... The car runs fine so not sure if this is OK or can I get a hotter spark. Where exactly would the resistor be to remove? I am using the throttle solenoid lead to power the Duraspark box and that is definitetly giving 12V+ when the key is on ...
