Motor mounts 200 vs 250
Discussion in 'Technical' started by Powerband, Jan 16, 2015.
  1. Powerband
    Powerband Member
    NY's \H/
    Anyone explain or better- have pics :
    whats difference between front motor mounts / brackets for '76 250 vs 200 ?.
    I have a '76 with a 200 and want to put a 250 engine in. The "insulator" or 'rubber mount' is the same part, are the frame brackets different or block brackets ? . What makes up for the wider block ( @ 1-1/2" ) ?.
    thanks
  2. rthomas771
  3. Powerband
    Powerband Member
    NY's \H/
    Thanks for the pic' , I would need to UN-shim to put a 250 in a 200 (narrower mounts) car but it confirms the different bracket theory. Probably will re-drill or help the 200 brackets to fit if 250's aren't found ...
    have fun
