more questions on dash bulbs!
Discussion in 'Technical' started by rocker804, Apr 25, 2008.
  1. rocker804
    rocker804 Member
    Middletown, CT
    72 Maverick 250I6
    so I took out the dash panel and i didnt realize there were 9 bulbs in it are they all the same bulbs or do certin ones go in certain spots can anyone recomment me a setup i wanna purhase all new bulbs?
    -Rob:dance:
  2. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Don't know if you saw the thread on dim dash lights but w5w bulbs are touted to work better for your application. I bought a pack but am not up to going through the knuckle busting of pulling my cluster yet.
  3. Jamie Miles
    Alto, GA
    I've had a few
    While all the bulbs in the cluster are the same, you only need to replace the three for the back light. I circled in the pic below what bulbs you need to replace. Sorry it's a fuzzy picture, took it with my cell phone.
  4. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
  5. Positively Ralf
    Yonkers, NY
    1974 Maverick
    Would those fit into a 1974 Mav dash without the need of some electrical work?
  6. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    The problem with LED's is either they are ON or OFF ... they will not DIM like standard bulbs ... and when they are on they are bright. Also if you go with LED's they must be installed with proper polarity or they won't work. So after installing them plug in harness .. if they are off flip them 180 degrees and try again.
  7. PaulS
    LEDs when running on AC have the correct polarity exactly half the time. LEDs can be dimmed because they are voltage sensitive. They are just about the perfect lighting solution.
