More Mav Problems
Discussion in 'General Maverick/Comet' started by texasjack, May 24, 2009.
  1. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Friday, I got my starter problem fixed. My fuel gage was working now it has quit working. Monday i am going to replace the little voltage regulator on the instrument panel. If that does not fix it I will be on here looking for a gas gage. I might be better off getting a complete instrument panel.
    I would like to get on with my body work if I could keep everything else from breaking.
    I will slide over to the parts needed section and see if anyone has an instrument panel.
    Texasjack
  2. mean_maverick
    i bet it's the sending unit for the gas tank....
  3. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Fuel Gage
    It was working fine then kput.
    I will ops check the gage Monday.
    Thank you
    Texasjack
  4. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Jack
    A quick of the gage is ground the hot lead at the tank if the gage goes to full the gage and wiring is ok sending unit is junk ..
    Jay
  5. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Gage
    Jay
    I will check that today.
    At my age it is hard to get up aftyer being under a car.
    Texasjack
  6. Craig Selvey
    When the instrument voltage regulator goes bad......the the gas gauge will read FULL all the time.
  7. texasjack
    texasjack Member
    Aledo, TEXAS
    1975 Mavrick 4 door
    Gas Gage
    I pulled the instrument panel and installed a new speedo cable.
    When my son comes out I will do the tank sending unit check out.
    After several trips under the car, this old man needs a rest.
    Texasjack
