mods needed?
Discussion in 'Maverick/Comet Projects' started by holmboy, Jul 19, 2010.
  1. holmboy
    holmboy New Member
    Hello all,
    New to the forum and have a question... looking at buying a 70 mav with a six cylinder in it. Are there any suspension or other modifications needed to drop a V8 in it? 302 or possibly 351W
    Thanks
  2. sam03rc
    sam03rc Member
    gates county, nc
    1972 maverick 302 C4
    youll need motor mounts, belly bar, 5 lug rear axle, and depending on what trans you have it might not be strong enough idk what trans can be used for both thou, the suspension is basically the same the spring rate is different but alot of people use the 6cly springs to be lower.
    if you put a 351 in there youll need to shave the shock towers to give you room for headers and to change your spark plugs
  3. lpolson07
    lpolson07 Member
    Des Moines
    76 Maverick, 72 Comet
    Check the tech article section it has a majority of the info you will be needing.
