"Modifying" the u-joint nuts
Discussion in 'Technical' started by scooper77515, Jun 29, 2007.
  1. scooper77515
    My u-joint nuts go on by hand...
    If I remember correctly, they were sorta squished when I first took them off, so they wouldn't come undone while driving.
    When I put everything back together, I was careful to mark the shaft-to-differential with white paint, and tried not to overtighten the nuts. But when I drove the car, it wanted to rattle to death at around 45 mph, and just got worse with a rhythmic pulsing/wavering sound and vibration.
    I got home, loosened the nuts DANGEROUSLY loose (maybe hand tight then 1/2-1 turn, and drove it and made it to 80 without any vibration (before I chickened out...probably SHOULD have chickened out way sooner:D ). I don't want to leave them on at approx 4 ft/lbs.
    Can I put them in a vise and gently squish them and then tighten them up to torque specs, or should I buy new nuts (CAN I buy new nuts?) that already have that squish to them?
  2. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Get some self locking nuts at any parts store. Should cure the problem.
  3. scooper77515
    Like the Teflon coated ones?
  4. Blown 5.0
    MS.
    1974 Maverick
    Locktite?
  5. MNTony
    MNTony aka Godzirra
    Surprise, AZ
    Buy the pre-crimped nuts that are fresh. Yours sound like they've lost their temper. Yeah, that's it...they are angry! Anyhow, if you can't find those (Ace Hardware has them) and you have enough length on the bolts you can use a lock washer on them. Many stock ones have lock washers and even my Moroso ones did. Hope this helps!
  6. NAFORD302
    NAFORD302 Member
    SILEX MO
    77 FACTORY V8 AC CAR
    Lock Tite
  7. NAFORD302
    NAFORD302 Member
    SILEX MO
    Locktite
  8. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    I think you can buy new straps and nuts together at the homozone. In the help section.
  9. NAFORD302
    NAFORD302 Member
    SILEX MO
    Precision Part# Is 534-10 I Don't Have Part # For Locktite
  10. 71gold
    (y)
    new u-bolts and nuts...:yup:
    ...:bouncy: ...
  11. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Yeah they're called Neuticles. :D
  12. scooper77515
    Neuticles...:D
    We need a link so everyone can experience them:clap:
  13. NAFORD302
    NAFORD302 Member
    SILEX MO
    locktite
  14. scooper77515
    I found them at O'Reilly in the help section, bought the 2 straps and 4 nuts, came with lock washers. About $6 all together.
    Also bought a 3/8" drive torque wrench so I can get them the right torque, and not guestimate...
    NAFORD, you at work today?
  15. Scotty P
    Scotty P Member
    santa rosa, ca
    locktite
