missing speedo cable
Discussion in 'Technical' started by Rickeeling, Mar 5, 2014.
  1. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    2 door 73 Maverick with a 302
    my 73 maverick did not have a speedo cable. I thought that it would be easy to just buy one for a 73 maverick 2 door with a 302 and a C-4 tranny but now I'm confused, in searching the internet for parts. (AUTO CRAFTERS) they have, 18 teeth, 19 teeth 20 teeth LH RH pink black yellow... How is my mind going to comprehend this complex conundrum that I have gotten my self into. I do have the gear in the tail housing. What length of cable do I buy and gear teeth, LH or RH helix?
    gnileekcir Thanks
  2. bmcdaniel
    I bought a universal Ford cable off the shelf at Pep Boys, just have to figure out what length you need. As for the gear, you have to know what rear gears and rear tire diameter you have.
  3. Craig Selvey
    If you would like a used Maverick cable, email me DIRECTLY (see below) and I can hook you up.
  4. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    I did some homework. Thanks to one of the replies that I received. Here is a math equation to determine gear teeth need for your speedometer cable based on tire size, rear end gear and the teeth count on the driven gear in the tail housing of your transmission. #Drive Gear Teeth X Axle Ratio X (20168/Tire Diameter in inches)
    -------------------------------------------------------------------- = # Driven Gear Teeth
    1001
    Example: 15 teeth drive gear, 3.73 axle ratio, 28" tire diameter.
    15 x 3.73 x (20168/28) = 40300
    40300/1001 = 40.26 or 41 teeth
  5. rthomas771
    16 tooth is the smallest tooth count they make/made
  6. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    sorry the math is for a 700R Trans. not a C-4.
  7. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    7 teeth drive gear
    3.55 rear end
    29 in tire dia.
    7x3.55x(20168/29) =17280.69/1001= 17.26 or 17 teeth driven gear. for a Ford c-4
  8. baddad457
    A C4 has 7 teeth cut into the tailshaft.
  9. baddad457
    Not sure how you figure to get a 29" tire in the fenderwells on a Maverick.
  10. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    I had my tape upside down measuring form right to left so I can use my right hand to jot down the numbers. well 26 upside down is 92, my brain read 29. mystery solved.
    FYI I did put my Nissan frontier tiers on my maverick for (S and G's) ****s and giggles. and they are 33's they fit. it was tight real tight, not practical or functional but they fit. If I knew how to add pictures I would show it to you guys.
  11. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    In my defense I'm 53 and it takes me a few day to figure out how to send pictures. so here they are. I hope.
