Maverick wont fire
Discussion in 'Technical' started by Ed's 75mav, Feb 13, 2005.
  1. Ed's 75mav
    Ed's 75mav Member
    Phoenix AZ
    1975 Maverick
    Hope you guys can help. Had to take the Mav in for emmissions and she had failed. took it to a mechanic and they told me to replace the engine since there was a little bit of water in the oil. Well anyone with comon sense nos that it would be the head gasket, so off comes the head and a new gasket is installed. Took her back in and she failed again. Took her back to the same mechanic and they said this time it was the carb, so I replaced it and all I could get is her to turn over but never fire, so I went and replaced the pick up plate on the distributor and that did not help, so then I went and got a ignition module with the green gromlet she would run just for a few seconds as long as I keept my foot on the gas pedal, then she would die. I would try to restart her and all she would do is turn over but not fire again I went and exchanged this module for a new one and the same thing but this time I noticed this module had blown a fuse inside the fuse box. I replaced the fuse and she still wont start.:banghead: the orginal module had a black gromet. any help would be nice.
  2. Tom Laskowski
    Tom Laskowski Member
    Bay Area,California
    (3) 71's,two V-8's and one 200 cid
    First off You'll need 13 quarts of Tranny Fluid.
  3. 71gold
    tom.....tom ....tom... tom.tom...:tsk: .
    ...frank...
