maverick rear
Discussion in 'Technical' started by dherzog, Nov 28, 2009.
  1. dherzog
    dherzog New Member
    lake placid ny
    1970 maverick
    out of what vehical can i get a 5 lug rear for my 70 maverick? any special yr or vehical? is there anything else ill need with it? changing from a 6cyl to an 8. thanks
  2. Mavman72
    Easiest way is to get a 5 lug from another maverick/comet.If and when you do get one...Check that the pinion yokes are the same.There were two versions on the 8" in a mav,one is slightly longer than the other...This can cause drive shaft length problems.Simple enough to change over though.Ford Granadas/Mercury Monarchs up to 79 have an axle that will work in a mav also...Good luck!!!
  3. dherzog
    dherzog New Member
    lake placid ny
    1970 maverick
    thats for the info.ill see what i can find. thanks again!
  4. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    Getting old an memory lost. 7.5 rear had different shock mounts. Do a search an info should be out there. Not sure which rear you have.
  5. baddad457
    Up to 1980, not 79. :thumbs2: The 80's are also the best chance of finding a 9" rear under one too.
