Maverick and Comet Torque boxes are available!
Discussion in 'General Maverick/Comet' started by Harlequin, Jul 26, 2011.
  1. Harlequin
    Harlequin Member
    Fayetteville NC, USA
    1973 Maverick
    3PG is releasing on August 1st Maverick and Comet torque boxes. They come in cold rolled steel and Galvanneal. Steel is thicker than factory on both types. Cold rolled is powdercoated in black gloss like the battery trays.
  2. mean_maverick
    curious to see these..
  3. 71gold
    :hmmm:...:huh: are they bolt in?
  4. Craig Selvey
    They are weld in. Come in (3) seperate pieces in order to accomplish this. I hope they post up some pictures.
  5. 71gold
    that's what i thought, so why...powdercoat...:huh:
  6. spork1o1
    spork1o1 Member
    Michigan
    found some pics online
  7. Dave B
    Wow!! I've never noticed that square hole, but they look pretty good.:thumbs2:
  8. 71gold
    what thickness are the stock boxes?
  9. mav1970
    Is there a price listed yet?
  10. mav1970
    Answered my own question - did a search and found that the un-galvanized ones are 80 bucks a side :)
  11. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    OK, stupid me, but what is a torque box and why do I need it?
  12. Dave B
    It's what ties the rocker panel into the front frame rails, a very common rust area.
    I have to say, Joe really came through on this. This is something that a lot of people can use. I congratulate him sticking with it, and getting them made.
    I will buy a set, even thought I don't really need them.
  13. mav1970
    Look under the floorboards of your car and you will find them in the 4 corners - the front ones are in the frame/firewall/rocker area and the rear ones are in the frame/rocker/front spring mounting area
    Kind of like really big complicated gussets :tiphat:
  14. Harlequin
    Harlequin Member
    1973 Maverick
    powdercoating
    The factory had uncoated torque boxes, they usually rotted from the inside out when the drain holes got plugged up with dirt and leaves and what not. The powdercoating gives them added protection, so that is less likely to happen. ;)
  15. Bryant
    is harlequin, joe?
