MAP sensor out of range??
Discussion in 'Technical' started by Richard Kuss, Jun 10, 2015.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    I recently had my maverick sent down to me from northern CA to southern CA out here in the desert were I'm stationed. And my car started running like crap. I check the engine code (eecIV) and code 22 popped up saying my MAP sensor is out of range. I haven't tested it with a multimeter yet. But the vacuum line to the manifold isn't damaged. So I'm not sure what it would be.. I know I have a small vacuum leak in the heater/AC system on the dash where the controls are. But I've had that leak for a few years now. I can only assume it popped up now cause of the elevation change on where I live maybe? I don't have my AC hooked up and I'm tempted to disconnect the heater and plug all those lines. Anyone have any advise?
    70 maverick
    91 5.0 ho Efi
    C4
  2. mav1970
    I didn't see what engine you had and all I could think of was "A MAP sensor in a 70 Maverick" LOL!
  3. Bryant
    is your car speed density or mass air?
    if its mass air, the map sensor should not have a vacuum line hooked to it. if its speed density then check for vacuum leaks and if none are found, you probably need a new sensor.
  4. Krazy Comet
    A '91 HO 5.0 doesn't have a MAP sensor(at least from factory), as they are mass air, so is used as a Baro sensor... Basically it's same sensor without vacuum applied...
  5. Richard Kuss
    Red Bluff Ca
    Well mine is a 91 5.0 ho and my Map sensor has a vacuum line that leads to the rear of the manifold
  6. Richard Kuss
    Red Bluff Ca
    My engine also came out of a markVII if thatakes a difference on the MAP sensor
  7. Krazy Comet
    It does(I'm slipping)... All MK-VII used speed densety and that requires vacuum routed to sensor... So yes you do have a MAP sensor... Mustangs all had mass air starting with CA in '88 and & '89 for 50 states versions...
    Here's a good trouble shooting article, though if the electrical connection and vacuum are OK it's probably bad...
    http://troubleshootmyvehicle.com/ford/4.9L-5.0L-5.8L/how-to-test-the-map-sensor-1
    Richard Kuss likes this.
  8. Richard Kuss
    Red Bluff Ca
    I have a question requiring this. bring up an older thread. we determined that my 91 5.0 ho has a MAP becuase it came out of a mark VII, but I'm curious why it also has a MAF? pic referenced can it run off both?
  9. Krazy Comet
    Then you must be using a Mustang 'puter if it has a MAF meter, no circuitry in MK-VII computer to recognize the MAF...
    Never heard of such but maybe Calif MK-VII used MAF??
    If it is a Mass Air computer there is not supposed to be a vac line on the MAP, as I stated before it becomes a Baro sensor, port should be left open...
