Lowered A-Arms
Discussion in 'Technical' started by NavMav, Feb 17, 2009.
  1. NavMav
    NavMav Member
    Tinker AFB
    Hey guys, I found this article and was wondering if anyone has tried it on a Mav/Com? It was developed for the early Shelby mustangs, but sounds like it could work. What do you guys think? :hmmm:
    http://site.cobranda.com/tech/aarms.pdf
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Yes, commonly called the Shelby drop
  3. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    Use the Search function, enter shelby drop = lots of info.
  4. PaulS
    You do have to change your alignment setting when you complete the "Shelby Drop". the camber is set to -1 degrees, Caster to +2 degrees, Toe-in is set to 1/8".
    With manual steering it is a little harger to steer but it will turn much better than stock. Add a 1 1/8" front sway bar and a 7/8" rear sway bar and you will swear the car is running on rails when you take a sharp turn.
