Looking for torque spec
Discussion in 'Technical' started by Scotty P, Jul 3, 2005.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    For the crank bolt that holds in the dampner...TXS Scott
  2. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    I always just put mine on "REALLY FREAKIN TIGHT!" 70-90 LBS ...
  3. rob's74cometgt
    rob's74cometgt Member
    Chilliwack, B.C., Canada
    74 Comet GT
    As tight as I can with a 1/2" drive!
  4. bmcdaniel
    Like Dan said, 70-90 ft-lb.
  5. 74merc
    74merc computer nerd
    1974 Comet
    its kinda hard to get 70-90 ft-lbs of torque on it, most of the time I just use the impact. Last time I actually tried with a torque wrench it was something silly like 35-40lbs before we couldn't hold the crank still anymore.
  6. bmcdaniel
    If the engine is in the car I usually stick a screwdriver or something through one of the holes in the damper and catch the oil pan rail to keep the crank from turning or if you have a manual trans and good parking brakes put the car in higher gear with the brake on.
  7. dmhines
    Cumming, GA
    Not sure if it is a good idea or not but it works. I pull one of the spark plugs and stick a long socket extension in there to keep the crank from turning ...
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    LOL! Don't think I'll try that one...
  9. scooper77515
    I tightened the fan belt really tight, and told my wife to hold the fan steady, while I cranked on it... :eek:
    Not really. Impact wrench will run it up tight without trying to turn the motor too much. Also nice to jam something in there, just in case, and to keep it from moving in case you are trying to do some timing afterwards.
  10. Scotty P
    Scotty P Member
    santa rosa, ca
    On engine stand, screw driver thru the harmonic, 90#'s no problem....
