long first gear
Discussion in 'Transmissions' started by zach71maverick, Oct 10, 2010.
  1. zach71maverick
    zach71maverick Member
    Buford, GA
    I have a c4 and its revs high before it will shift to second gear. It shifts fine but it just takes so long to get it to go into second. I checked the fluid its a good level and its not burnt. Also I replaced the modulator (green stripe).
    Any other suggestions?
  2. don graham
    Did it do it before you replaced the modulator? I'd wait for PaulS to answer. The onlly other thing I'd try is to adjust the modulator. But I don't know beans so I'd wait for the experts to chime in.:)
  3. zach71maverick
    Buford, GA
    yea it was doing it before I replaced the modulator and is still doing it...haha thanks
  4. PaulS
    Check your manifold vacuum. The C4 needs at least 10 inches of mercuty of vacuum to shift. If your engine id worn or has a lopy cam the vacuum may be low enough to affect the shift timing.
    While you are checking things check to make sure you kick-down linkage is free and working properly.
  5. zach71maverick
    Buford, GA
    just checked the kickdown and it is adjusted correctly and everything is good with that, I couldn't find my vaccum guage so I havent checked on that but the motor probably has 5000 or so miles since rebuild and the cam is just a stock roller cam from a 92 mustang, so I dont think that is the problem...Any other ideals?
  6. simple man
    simple man Member
    Bunnell,Florida
    When you replaced the modulator was there a small rod in the old one? If that is missing the trans will not shift correctly.:)
  7. zach71maverick
    Buford, GA
    yes there was and I put it back in with the new modulator!
  8. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    check with Paul on the proper length of that rod. It is here somewhere if you do search.
  9. PaulS
    Are you sure that you got the rod back into the hole in the spool valve?
  10. zach71maverick
    Buford, GA
    I pretty sure but I will re-check it.
  11. zach71maverick
    Buford, GA
    I feel like an Idiot, PaulS you were right about the vaccum , some how I switched the vaccum lines so therefore it wasnt getting any vaccum, but it is all fixed now!
    Thanks
  12. PaulS
    It can happen to anyone! Glad to see you are running again.
