lockout the shift linkage
Discussion in 'Technical' started by BigDog41364, May 14, 2012.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I was reading a post from a few years ago about converting a column shifter to a floor shifter and some one mentioned you need to lock out the column shift linkage so it does not lock the steering wheel while your driving. can some one enlighten me on how do you do this?
  2. Joe Dirt
    ive never had a issue
  3. sdb416
    sdb416 Member
    TEXAS
    No Maverick now
    I just left the collar on and removed the bar. I move it into D when im driving around and when im done move it back off and pull the key out.
  4. bmcdaniel
    I disassembled the column and removed all of the old shifter parts. Grind and body filler the shift lever hole and no one knows there was ever a column shifter. This was a manual trans shifter.
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I made a simple metal strap that bolts to the original linkage hole on one end, and to the master cylinder mounting bolt on the other end. Painted it black, and you never notice it....
