Little plastic yellow box
Discussion in 'Technical' started by CommieHook, Nov 10, 2011.
  1. CommieHook
    CommieHook Member
    Hot Springs, AR
    1974 Ford Maverick 4-door
    So I am removing the lower part of my dash last night for a stereo installation, and on a small tray screwed to the bottom of the dash is a yellow plastic box. I did a search on here and discovered that it is the "seatbelt box". My question is what will happen if I disconnect it and don't put it back? Anyone tried it?
    Thanks,
    HHJr
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If you just disconnect it the car won't start. It can be bypassed, instructions are in the seatbelt interlock threads.
  3. rthomas771
    After it is bypassed...then you can remove the yellow box and zip-tie it's wiring harness out of sight
  4. Craig Selvey
    No real need to remove it. Just consider it a "quaint" treat for 1974. :D
  5. CommieHook
    CommieHook Member
    Hot Springs, AR
    No worries, I put it back from whence it came. Thanks guys!
