LIL Betty II my 71 Maverick
Discussion in 'Maverick/Comet Projects' started by maverickdean71, Jun 24, 2015.
  1. maverickdean71
    maverickdean71 Dean Mikel
    Perkinston, MS
    I bought the car as a rolling chassis for $2500.00.
    Then I purchased a Rod and Custom Mustang II front conversion with 2 inch drop spindles.
    Now that the front has the right stance now back to Savage Performance to get the back right. Had a custom 4 link designed for the back with a 9 inch rear end and 96 Mustang disc brakes.
    Grafted a 1968 Shelby GT500 tail light panel into the back. With a 69 Mach 1 hood scoop with functional turn signal indicators that will work.
    Power comes from a 351W with an Ford X303 cam and a Trick Flow upper end. Controlling the motor is a 92 mustang CPU using Ford motorsports hot rod wiring harness. Going thru a T-56 transmission. Using a American Power Trains Hydraulic clutch master cylinder and throw out bearing.
    Brakes will be controlled by a Rod and Custom Power brake booster with a Wilwood master cylinder. Went to painless for my wiring needs and Ididit for my steering column. New 19 gallon gas tank and installing an in tank fuel pump to feed the motor.
    Rims are from American racing I have 17X7 with 225r55/17 in front and 17X9 with 275r45/17 in back.
    when I get more done I'll post more.
    MDE, CaptainComet, mojo and 3 others like this.
  2. 71gold
    :thumbs2:...can you tell us more about the...custom 4 link?
  3. junrai
    junrai Member
    rancho cordova ca
    go on.......................tell us more.........................dont be stingy .............................tell us everything .....................I see lots of good stuff happening I thought WOW $2500 for a rolling shell BUT I can see how just about perfec tthe body is so I guess its a trade off more money no rust or dents even a decent looking original paint job or LOTS rust and less money
  4. maverickdean71
    Perkinston, MS
    71 Maverick 48.jpg Lower control arm comes out from the front spring perch to axle.
    71 Maverick 58.jpg 71 Maverick 59.png Two cross members where welded in to tie the upper control arms to and the aft one to mount the adjustable coil over to
    71 Maverick 56.jpg normal_107_0170.jpg Here are the 4 control arms Being painted. They have the adjustable ends on both ends and on all 4 control arms.
    71 Maverick 63.jpg Here you can see how it is tied to the 9 inch axle.
    71 Maverick 50.jpg 71 Maverick 51.jpg Here is how the Shocks are mounted.
    71 Maverick 53.jpg 71 Maverick 52.png Here is what it looks like in the car.
    MDE, Backtooldschool and Kenn like this.
  5. mav1970
    Very nice job on the fab work :thumbs2:
  6. maverickdean71
    Perkinston, MS
    Thanks my Buddy did the work from my ideas.
  7. maverickdean71
    Perkinston, MS
    Look At the pictures I put on the thread.
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That's awesome. 'Love the wheels.
  9. maverickdean71
    Perkinston, MS
    Thank you. It's my Baby!!
  10. 71gold
    thanks for the pics and discription...:Handshake:
  11. maverickdean71
    Perkinston, MS
    I hope it helps others do similar.
  12. Kenn
    Kenn Member
    1995 Ford F150, 2005 Ford F150
    Hi,
    Ending my first week here at this site. All of you guys have inspired me and shows me what I can do. Great looking build; I hope to see more.
    Kenn
  13. maverickdean71
    Perkinston, MS
    J
    Just have fun with your build!!
    Kenn likes this.
  14. Paul Masson
    1971 Grabber
    GREAT build! :thumbs2:
  15. maverickdean71
    Perkinston, MS
    Thank you.
