LED Shelby tail lite kit (pricey but cool)
Discussion in 'General Maverick/Comet' started by white trash, Oct 7, 2008.
  1. white trash
    white trash Member
    Leland, NC
    1969 1/2 Maverick 6cyl auto field find junker
  2. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    It sounds expensive until you try to put one together yourself. I have almost that much in mine and I'm still using incandescent bulbs.
  3. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Yeah, those have been discussed before. They are neat, but pricey...
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    SWEET!
    Another great thing that can be done with our cars.
  5. ratio411
    ratio411 Member
    Pensacola
    I figure if I could ever afford a set of those...
    I would take out the 4 studs that fit the Mustang, then redrill them into the housing back, in the Maverick tail light pattern. That way there is no cutting to the tail panel.
  6. newtoford
    newtoford Member
    New Castle Delaware
    by the time you get actual 67 shelby (67-68 cougar) tail lights, make a harness, get a sequencal box (or w/e its called), the fibergalss tail panel over lay and cut everything to fit and make it all work that $500 looks like a good deal
  7. white trash
    white trash Member
    Leland, NC
    I guess it's a good deal for what it is. They are really cool lights but just not my thing. I actually like the stock Maverick tail lights. That's one of my favorite parts on a Maverick. I see a lot of people like to change them to Bobcat lights or whatever. For me I am just going to add those LED 1157 replacement bulbs for a little brightness and that's all. To each their own, no right or wrong here that's for sure.(y)
  8. don graham
    For $500 I'll do something else that I need first.:)
    WiscoMav likes this.
  9. white trash
    white trash Member
    Leland, NC
    I would think the actual Ford lights would be more than these. I was thinking more along the lines of $500 in general for a set of tail lights is pricey to me. Maybe I'm just cheap:huh:
  10. bmcdaniel
    I've seen two Mustangs with those conversion lights, they are really thick for some reason, sticking out past the tail panel surface.
  11. bimbobreadman
    bimbobreadman Member
    Sherman, TX
    73 Maverick 2dr
    looks kewl! Good Idea as well. Ive seen a few pics of other Mavericks with this style tail lights. Doesnt look bad, but I like the original look.
  12. newtoford
    newtoford Member
    New Castle Delaware
    i think these kits dont require the tail panel to be cut out so everything has to fit between the panel and the lens
