led or hid headlights?
Discussion in 'General Maverick/Comet' started by x72COMETx, Aug 5, 2015.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    the stock lights on these cars suck and i wanting to upgrade everything to led so i was wondering if led is better then hid for headlights
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    I think the stock headlights work just fine.
  3. rthomas771
    Put relays on your stock headlights
    maverick1970 and 71gold like this.
  4. Wolf Mcbee
    Wolf Mcbee Member
    1974 Ford Maverick
    I ended up getting some clear lens 7" headlights off amazing for $17, I have tested them on my car but that was till the battery died, the lights use removable halogen or h2 bulbs I believe? Forgot what they are but there bright so I'm pleased
  5. 71gold
    went with the relays and no problem with seeing...:thumbs2:
  6. Eli Lacy
    Eli Lacy Banned
    1970 ford maverick(grabber clone)
    How do you add these relays in??
    Crazy Larry likes this.
  7. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Eli I did a tech artical it is on this form follow the diagram not the text your lights will be much brighter.
  8. junrai
    junrai Member
    rancho cordova ca
    I want to get some relays and maybe hid lights
    I have tri bar headlights with the removable halogen bulbs but they suck as bad as the factory lights. I like those lights that some of the newer cars have that are SUPER bright white not yellow or orange
  9. 71gold
    no relays is the problem with your tri bar headlights . just not unough juice through the headlight switch for any lights.
  10. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    Yep ! Relays really work .. been running tri-bars for years .. they're as bright as I need them to be !
    Cometized
    (Chip)
  11. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    I put 8000k hid h4 on my 74 and 3000k in my factory fog lights and led lites in every bulb in the car in order for the turn signalsto work you have to switch out the flasher to the led one with the ground wire coming out the top and take a tiny screw driver in the plug to release the connector and switch them to the other because the power is in the wrong side of the plug for the flashers to work and if the lense is yellow get yellow leds or they will look greenish. Mine look grate
  12. 71gold
    1974grabber likes this.
  13. 1974grabber
    1974grabber Member
    buffalo ny
    1974 grabber
    I think they might be directional pacific! !!!!
  14. 71gold
    ...:biglaugh:...
  15. 71Mavrk
    71Mavrk Member
    Nevada
    X2 on the relay set up.
    I'm running Lucas European lamps with Sylvania H4 bulbs and a set of Lucas Square 8 driving lights. See avitar for how bright they are in the daytime.
    Micah
