leaf spring clamps?
Discussion in 'Technical' started by car-nut, Jan 24, 2010.
  1. car-nut
    car-nut Glenn
    conn.
    I have taken the rear springs apart and am having them blasted. I am going to repaint them and then reassemble. I had to cut off the band clamp that each spring had.
    I assume they need to be replaced? Where can I buy them?
    There isn't a spring shop around here to take them to.
  2. Mavman72
    If you cant get em locally or find em anywhere...I have a Spring shop locally that has em/makes em...Let me know and I will hook you up.Got some for the Sprint if I find the reciept Ill post the price up for you.
  3. car-nut
    car-nut Glenn
    conn.
    Thanks, that would be cool of you. I don't know of any spring shop around here. Autocrafters lists them, but theres is for a 4 leaf spring. I have the 3 leaf set up.
    Glenn
  4. Mavman72
    You have a PM :Handshake
  5. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    Two places I know of in Conn. are Spring Replacement in Bridgeport, or Superior Spring in North Haven. I don't know if that is any help to you.
  6. PaulS
    When assembling the spring stack don't forget to use some muslin and grease between the leafs. That keeps them from squeaking and makes them work smoother.
    I am not sure you will find it in any books but it is a trick that an old timer taught me long before I became an old timer myself..
  7. Dave B
    National Parts Depot sells them, for Mustangs, they can't be that much different.
  8. Blown 5.0
    MS.
    1974 Maverick
  9. car-nut
    car-nut Glenn
    conn.
    Interesting read... thanks! I did come up with a set of clamps. Springs&Things (Espo) has them. They are on their way to me now.
  10. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Oh, they changed up their webpage! How do you find them on there? Can you state the part number and price?
    Thanks!
  11. rthomas771
  12. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    No wonder I couldn't find them, that's Eaton, not ESPO. :hmmm: Good find though, thanks! But...I think our springs are 2 1/2", not 2" (32KK9)?
  13. rthomas771
    Sorry about that. I was looking for parts for my Falcon. 2.5" clip is $3.95 each also...rubber is $1.75 each
