KKS 3 Row Aluminum Radiator
Discussion in 'General Maverick/Comet' started by Richard Kuss, Feb 5, 2016.
  1. Richard Kuss
    Richard Kuss Kusstum Fabrication
    Red Bluff Ca
    1970 Ford Maverick, 1970 Maverick parts car
    http://www.ebay.com/itm/KKS-3-ROWS-...e89a9cda:g:YKkAAOSwp5JWUG-u&vxp=mtr#vi-ilComp
    anyone ever used one? I searched the forum and couldnt find anything. its about $100 cheaper than the champion 3 row with shroud... I'm debating trying it. thoughts/opinions/suggestions?
    looking to cool down and free up alil hp on the belt with the electric fan.
    I dont know how much HP i have. I know I wanna stay under 400hp.
    Spec:
    91 5.0 ho cobra efi (stock)
    C4 pan fill, converter unknown.
    serp beltdrive with manual steering, Smog pump and AC delete.
    longtube headers/dual flowmasters
    9inch 3.89 w/Detroit
  2. William623
    William623 Member
    Orlando
    1973 ford maverick grabber
    I went with a champion, but I kept a watch on eBay until I found one that had a small dent and got it for way less. It was brand new in the box, if you have a bit of time keep an eye out and they pop up fairly often.
  3. Richard Kuss
    Red Bluff Ca
    I ended up going with champion
  4. Jony
    Jony Banned
    1972 Ford Maverick Grabber 5.0L 302 v8 NA
    If that radiator does work please tell me but I have to say that I also tried an aftermarket radiator that was a bit different and was disappointed. It didn't have rounded edges but everything else was the same. Be careful because when I tried to install the aftermarket radiator from ebay it turned out that not only did the radiator not line up with the bracket but it was to tall and wide! You might have to trim a bit but in the end I returned it and bought an original stock 2-row radiator at a local auto shop near me.
  5. Richard Kuss
    Red Bluff Ca
    I went with a champion 3 row. Buy once cry once
  6. William623
    William623 Member
    Orlando
    You will have to trim a bit of your lower brace, but it's a relatively easy installation. Seems to work great so far!
