Key Minder Switch
Discussion in 'Technical' started by BigDog41364, Aug 25, 2012.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    A week ago my turn both left and right turn signals quit working :hmmm: so i have been looking at the wiring diagram they are controlled by the key minder switch. I also on a couple of occasions sense the signals quit have gotten a small shock when turning the key off. so im thinking the key minder switch is shorting out. My question is where the switch located and how do you get to it?
  2. Craig Selvey
    I have never heard of such a thing.
    :huh:
  3. rthomas771
    The arrow points to the key minder wire. It's not tied into the TS switch
  4. simple man
    simple man Member
    Bunnell,Florida
    I would check your fuse and then the flasher unit to start with for your no turn signal problem. I'm with Craig on the " key minder ", I've never heard of that either! I do know some later model Fords had a buzzer that would come on if you opened the door with the keys in the ignition. I don't know if this is what you're referring to or not? How the key can shock you is really beyond me! :hmmm: Someone may have had this happen to them, so hang in there and I'm sure we all can get this solved! :)
  5. Mavaholic
    That switch provides a ground to energize the buzzer so it shouldn't be a source of any shock.
  6. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    This is what im looking at on the wiring diagram. after looking at it a little closer I think the key minder switch is referring to the wire. I guess I should start this thread over..LOL
    Hey guys, my turn signals quit on me, left and right at the same time. any ideas what i should check? the circus is in town so im hoping to hire a "contortionist" to check the fuse fore me because my 300Lb but cant fit up there with out removing 1/2 the interior :rofl2:
      File size:
      801.1 KB
  7. MSmithPDX
    MSmithPDX Member
    Portland, OR
    I lost mine when the hazard switch broke in the steering column one time. I actually rewired almost the entire turn signal set-up before I found that out.
    Hope that's not it though.
    I totally feel you on the contortionist thing though. At 300+ and 6 and a half feet I work my fuse box blind. It's not change 1 fuse its change ALL fuses until I find the one that burnt.
  8. rthomas771
    Y'all need to relocate the fuse box like in the Tech article. My fusebox is about even with the steering column.
