Just another question about 351's...
Discussion in 'General Maverick/Comet' started by ShuttleMav, Jun 17, 2006.
  1. ShuttleMav
    ShuttleMav Member
    Does anyone know the EXACT difference between the Cleveland and the Windsor 351's? Whether it's specs or design. I'm sure you guys will give me a detailed answer. Thanks you guys!
    Scott
  2. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    As for the differencees, it would be easier to tell you what is the same. The onlt thing they have in common is 1. CID and 2. cylinder bore spacing. Other than that they are completely different.
    Hope that helps
    Don
  3. QuarterHorse
    QuarterHorse Member
    Des Moines, Iowa
    An easy way to think about it is a Windsor, being a Windsor based motor is almost the same as a 302, just a taller deck height. A Cleveland, being FE based, is closer to a 385 series motor being a big block.
  4. cjjtulsa
    cjjtulsa Member
    Oklahoma
    1970 Torino Cobra 429CJ/4 Speed
    No - not FE based; the FEs are the big block 352 thru 428s. The 385s are the other big block 370-460s. The Cleveland is in the 335 series family, and they are different than all the rest. They have an cast-in timing cover, dry intake, and canted valve heads (similar to the 385s).
  5. ShuttleMav
    ShuttleMav Member
    So, what you guys are saying, or what I'm getting out of this, is that the Cleveland is like a big block, and a Windsor is like a small block, for the most part....
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The term small block and big block is more of a Chevy term. But if you must the Cleveland is a smallblock. The Cleveland is a 351 CID engine with canted valve heads cast in the Cleveland, OH engine plant. The 351 Windsor is a 351 CID inline valve engine cast in the Windsor Ontario engine plant.
    If you are starting from scratch the Windsor will likely cost less to build for performance purposes due to the large aftermarket offerings. Although there are some new cylinder head offerings from both Edelbrock and CHI.
  7. ShuttleMav
    ShuttleMav Member
    Dude, I obviously know that, but I mean like, it seems like ppl are sayin that the cleveland is a small block that acts like a big block, and a windsor is a small block that acts like a small block... so, lemme ask this, what will the difference be between me putting a cleveland in my car and putting a windsor in my car....
  8. sierra grabber
    sierra grabber Certifiable
    northern nevada
    from what ive been reading on this board, i think cost is going to be your biggest difference. the cleveland and windsor will both require some fitment mods. i would price the parts required and then look at your planned funds to see which block you can build up more for the remainder of those funds. if money is no object, look at the man o war blocks and see if you can even get a cleveland. again, assemble from there. If your wanting a detailed answer on something more specific, then just ask that specific thing. were all just maverick drivers, not mind readers. we really do want to help
  9. QuarterHorse
    QuarterHorse Member
    Des Moines, Iowa
    Ya know, after I walked away from the computer my poor brain zapped me and I remember this haah.
  10. maverick1970
    Missouri
    Nothing is obvious at this point you have two threads talking about Cleveland - vs Windsor 351's.
    The design is different, they share bore spacing and CID and bellhousing bolt patterns , not many parts interchange between the engines without modifcations.
    The Cleveland was offered with 4 bolt mains
    The Cleveland is slightly dimensionally larger and heavier than the Windsor
    http://www.geocities.com/infieldg/v8enginesizes.html
    http://www.fordcobraengines.com/engine_weights.htm
    Neither engine was offered by Ford in a Maverick
    The Windsor has a larger aftermarket following
    Use of either engine will require mechanical and fabrication skills
    The Cleveland will be more expensive to build
    What exacrly do you want to know?
  11. cjjtulsa
    cjjtulsa Member
    Oklahoma
    That's not necessarily true, and I hashed it out on another thread here. Looking at S(c)ummit's website, a general rebuild kit, with forged pistons - both run around $489 for a 351C, and $459 for the Windsor. For the most part they are almost identical price-wise, it just depends on what flavor you want. You can't really go wrong with either.
  12. maverick1970
    Missouri
    That may be true but look at performance cylinder heads and intake manifolds. Not to mention the variety available. Also compare the costs of Stroker kits between the two.
    I am not against the Cleveland, actually I have 3 of them and only one Windsor. But if I was to build another engine it would be the Windsor and it would be a stroker.
  13. QuarterHorse
    QuarterHorse Member
    Des Moines, Iowa
    Already said, but you can't base the cost of pistons over the total build, there are a few more pieces than that. As meantioned heads, intakes, also headers, rotating assemblys as a whole. You'll be ahead with the Windsor with money in the bank. A Cleveland really shines in all out racing where those monster heads have the R's to make the HP. Street/strip set ups I'd give the nod to the Windsor every time.
  14. cjjtulsa
    cjjtulsa Member
    Oklahoma
    Pull up a list of parts - other than stroker kits - and show me the real world price difference. There ain't any. My last 302 cost more than my 351C did to build. The "monster heads" thing doesn't hold water as the Boss351 Mustang was obviously a Cleveland, and was one of the fastest Mustangs - big or small block- ever produced. Not trying to argue, but I've encountered this arguement in every forum I've gone to, and it doesn't hold water at all. Both are great engines, and cost the same to build if you don't stroke them. There I'll concede to the Windsor, and still it isn't by much. You can get more displacement out of the W though.
  15. Jamie Miles
    No, it's actually not obvious at all.
