Jamed door lock
Discussion in 'Technical' started by Al Martin, Oct 11, 2008.
  1. Al Martin
    Al Martin Member
    central michigan
    72 maverick
    Hello everyone,
    Drivers door lock is froze up and wont turn with the key. Cant move the lock pull-up on top of the door either. Pulled back the door panel back and all linkage was in place.
    Any suggestions? Thanks.
    Al
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    lube all moving parts.
  3. 71gold
    go to the other door and see how the lock works on it, then see if you can find what is sticking on the other side. you may also want to take the rods loose in the stuck side to tell which part is stuck...(y).
    ...Frank...:yup:
