I've almost got a floorpan again
Discussion in 'General Maverick/Comet' started by 74merc, Mar 23, 2005.
  1. 74merc
    74merc computer nerd
    1974 Comet
    So far so good. I've been fiddling with it since Sunday afternoon, today I stood and jumped on my new front passenger side floorpan.
    Completely made from sheetmetal, still bracing it up and such, but its in there... now to finish the driver's side and get my cowl from Chandler, drop the 351 in there, I'll be good as new in another year or two... lol
  2. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    sounds great!
    pics pics.
  3. Jamie Miles
    Alto, GA
    I've had a few
  4. stmanser
    Davenport, Iowa
    hey 74 merc what did you use for the floor pans...i need to fix mine up....
    thanks
  5. 74merc
    1974 Comet
    Apparently I don't have a before shot of the floorpans...
    I'll post a pic of the new floorpan itself this afternoon.
  6. 74merc
    1974 Comet
    I used 20 guage (pretty sure its 20) sheetmetal and lots of time...
    The sheetmetal is almost twice as thick as the metal it replaced, and its still thin enough to burn a hole in a heartbeat.
  7. 74merc
    1974 Comet
    Drivers side
  8. 74merc
    1974 Comet
    new passenger side
  9. Jamie Miles
    Alto, GA
    I've had a few
    Looks good. (y)
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    looking real good!
    I hope to develope those skills in the years to come.
  11. Grabber75
    Grabber75 Member
    Mount Vernon, Ohio
    1975 Maverick Grabber
    hey 74merc a little tip for ya. when i did my pans they had a slight "oilcan" effect to them. i just found the high spot and run a bead of weld across it to tighten it up. worked really well.
  12. stmanser
    Davenport, Iowa
    looking at yours inspired me to get mine redone.....i had a guy use glavanized to do mine and it served its purpose but now i need more strength....
    today after work i striped the interior.....everything except the dash and head liner is out...the carpet was trashed anyways and the seats need to be redone....i had my son clean all the dirt out...and i will get a saws-all from my friend tomorrow and cut the sections out...i found a donor mav in the junkyard... the guy wants 100 bucks for the floor pans...
    just need to find someone who has a portable welder and can teach me....
    then once it is all welded i will paint the interior and sound proof it a little...
  13. Mavaholic
    Looking real good.
  14. 74merc
    1974 Comet
    Driver's side is out, grinding away at the spot welds now.
    For anyone looking to do this, a 3/8 spot weld drill bit makes it much easier. I tore most of the floorpan out with a pair of lineman's pliers after the first cut, hit the welds with a the bit (gotta have a center punch to keep the bit from walking), and gave it a good yank.
    A die grinder is almost required for a straight line along the edges.
    Grabber75, you mean where the floorpans pop? Strategic welds work wonders don't they?
    I had planned on welding in a tiny piece of angle to prevent it, but once I welded the bottom side of the subframe to the floorpan it drew it right up. I doubt I'll get that lucky on the driver side.
    Home made subframes are the next project, depending on when I get the cowl. I'm trying to stiffen up the body a bit as I've always had an irritating vibration. It seems to be a unibody feature...
