it's getting cold here
Discussion in 'Technical' started by noun, Nov 9, 2008.
  1. noun
    noun Member
    San francisco, CA
    76 mav'
    hi every one!
    ok... weather start to get cold here in nebraska:D
    car start pretty good still, but here is my problem:
    the heat works great for the winshield, but i get cold air from the sides (the one for the driver or the passenger...)
    any ideas?
  2. Mavaholic
    Usually its the heater core.
  3. 71gold
    i would think...heater control...defaulted to defrost...:huh:
    the control has lost vacumn...either...hose leak/disconnected or...the plastic part of the control is broken...is this an A/C car?
    ...Frank...:Handshake
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    you don't still have your vents open do you :huh:
  5. noun
    noun Member
    San francisco, CA
    76 mav'
    ok... so... if i open the vent... of course it's cold since i get the air from outside right?
    but if i close them.. i just don't get any air... hot or cold....
    BUT the air blowing on the windshield is hot and strong enough...
    yes it was an A/C car... but A/C not on it anymore...
    how the heat core could be the problem if it's blowing hot air on the windshield?:)
    thanks for your answers...:)
  6. noun
    noun Member
    San francisco, CA
    76 mav'
    whereor how do i check that?:)
  7. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    heater
    When you select heat, a flap should open letting hot air out near the floor. This can get stuck shut. Pop spilling down the defrost opening will do it.
  8. noun
    noun Member
    San francisco, CA
    76 mav'
    ok.. i'll try that... thanks:thumbs2:
  9. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    '72 mav 2dr, '70 mav 2dr
    what's "pop" and what are heaters used for? never heard of those before...
  10. JAYSMAV
    JAYSMAV Member
    Ohio
    "pop" is a soda drink. Heaters keep us up north from frezzin our cheche's off :)
  11. LSU2010
    LSU2010 Brandon B
    Baton Rouge, LA
    ah, papa used to tell us stories about heaters and pop, I didn't know they were real...:rolleyes:
  12. noun
    noun Member
    San francisco, CA
    76 mav'
    ok.. so after checking everything i just guess that the openings ON the dash are for the vent...
    and the openings UNDER the dash are for the heat.
    which means my heater core is working good i guess:clap:
