it just keeps adding up
Discussion in 'General Maverick/Comet' started by bartikus, Apr 22, 2005.
  1. bartikus
    bartikus Member
    salt lake city, ut
    so i pulled an engine out of a 74 maverick grabber. it is a 302 and i was really happy about it then. so i decied to do a small refresher on it. i was going to replace a few gaskets and the valve guide seals. but when i pulled off the valve cover it was completly covered with sludge. so i decided i needed to pull the rest of the engine apart to clean it all up. then a guy that lives across the street from my friend came over and said i should really make sure the sludge wasn't up around the rings. then my friend suggested that i should just buy new rings. so i get new rings and to top it all off my dad comes over and looks at my engine tonight and he just touches the timing chain. and it is way too loose. so it's off to auto zone again to get a timing chain and gaskets. the moral of the story is, never think that a job is going to be simple and quick. it always takes 3 times as much effort to do and 5 times as much money. i'm just waiting to see what i have to do next to my 302. but the good thing is i'll have a really good running motor.
  2. Jamie Miles
    How true is that! For us, a quick spark plug change ended up costing over 100 bucks, took 5 days, and had to pull the whole top end of the engine apart. :huh:
    Sometimes stuff just keeps snowballing on ya.
  3. 71gold
    might i suggest that you go ahead and pull the crank while you have the rods out and have it "polished or turned".:huh: if you put the new "rings" in your compression will go up and you need to make sure your rod and main bearings can hold up...that one size bigger cam i put in mine sure pepped it up :bananaman , also might want to put a set of new lifters in while you have the cam out.:yup: new cam bearings will insure good "oil pressure". just a few things you might want to think about...frank...
    p.s. new freeze plugs would be a "plus.:yup:
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    wasn't we talking about the snwball affect a while back
  5. Jamie Miles
    Way to go Frank! Pile up more stuff for him to do. :rolleyes:
    Of course thats the diffrence between getting it done, and getting it done "right". :bouncy:
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If your in it that far put a new oil pump in it. Think of it as the heart of your engine!
  7. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I agree with Frank and all above. Might as well do it right the first time now while the engine is out........a lot easier now then to have to pull it back out later and re do again 'cause something broke. Just my :2cents:
  8. stmanser
    Davenport, Iowa
    dang if you already have it apart you may as well do it all right....that way it wont have to be torn apart later.... yeah it may cost more but you can do it in stages....
    i had my short block and heads done 1-2 months before i yanked the 170 out....and then i got all the little pieces during that last month or so....
    you will be morehappy not having to take the block out because you said, :ill worry about that later." and later just happens to be a month down the road
    just my $.02
    good luck and i hope it all turns out for ya
  9. Mercurycruizers
    Venetia, PA
    Yes, it's called the snowball effect. When you replace the oil pump, might as well get a finer mesh screen & the beefer oil pump shaft. My mistake when I rebuilt mine. Sucked up a piece of gasket silicone & twisted & broke the stock oil pump shaft. It's a bummer to watch oil pressure go to zero, when you don't have 20 miles on the engine....lesson learned. "Do it right, the first time".
  10. mavman427
    mavman427 has entered the building.
    SLOtown, CA
    1971 Mav with all the trimmings....302 Auto, Custom buckets, Power Brakes, A/C, PS, Grabber hood, spoiler, and mirrors.
    Sounds like it's time for a rebuild :).
  11. 71gold
    bartikus buddy,
    you didn't faint on us did you?? hello!! hello!!!:huh: ...frank...:bouncy:
  12. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Hang in there Bartikus!! It's gonna be rough for awhile, but what the guys have said up above really is true. It seems to be such a HUGE problem, and while I'm not saying that it's minor, it will get better. Just back off, take your time, watch ebay, :D and pick things up little by little. It WILL pay off, I PROMISE!! Good Luck man, and remember that we are all pulling for you!!! Take care.... Preston
  13. ford84stepside
    Berry Alabama
    Good advice, Countrymav! Nothing wrong with the Johnny Cash approach......One piece at a time! I'm doing the same thing, when I get all the pieces I will start putting it together! No reason to do without just to buy engine parts, take your time, do it right and you will be better off in the long run.
  14. bartikus
    bartikus Member
    salt lake city, ut
    well the really funny thing is that the engine wouldn't need to have this done, but some one before me didn't repalce the oil on a regular basis. the compression was really even before i tore into it and the rod bearings look pretty good. which i was suprised about. every thing in the engine looks in really good shape exept the timing chain and every thing was dirty. i would be doing a little bit of modifiying it, but i really don't have that much money and i really can't wait that long to get it fixed because by engine in my car is croking.
  15. 74merc
    74merc computer nerd
    1974 Comet
    My folks ran Quaker State in their 78 Impala, 350. You could not see the rockers after pulling the valve covers. Changed every 3000-4000 miles.
    Needless to say, we don't run QS anymore...
