Interior door paint ???
Discussion in 'Cosmetic' started by BOSSv10, Apr 30, 2007.
  1. BOSSv10
    BOSSv10 Member
    Chicago, IL
    '73 Maverick Grabber
    What kind of textured paint is used on the inside of the doors ? At first I thought it was part of the steel but when I wiped it down with reducer it wiped smooth. Is it just regular wrinkle paint or is there another way it has to be done ?
  2. scrapper60
    scrapper60 MCCI Member
    Alabama
    What year model? It was textured steel on the early models. I don't know when they changed to smooth, maybe 73/74.
  3. BOSSv10
    BOSSv10 Member
    Chicago, IL
    Its a '73
  4. Craig Selvey
    Changed to smooth mid to late 1976 thru 1977.
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    It they are smooth inside .. then they are not the original doors ..
  6. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Maybe somebody sanded them smooth?:hmmm:
  7. Craig Selvey
    It would take a LOT of sanding...as the texture is "cast" or "pressed" right into the metal. Would be easier to fill with putty.
  8. BOSSv10
    BOSSv10 Member
    Chicago, IL
    The doors are textured everywhere but the one spot I cleaned, but it was textured to begin with. If they are the wrong doors then I wish I knew how they got the paint like that. They look the same as my '71's.
  9. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    The earlier doors were cast to look like leather or some material. It's not the paint. It is possible that someone sprayed yours to look like they were textured. Maybe with bedliner?
    Later doors are smooth metal as Mr. Craig Selvey stated.
  10. DaMadman
    Southern MD
    Maverick 1972,1970,1973
    are you talking about this part of the door in the attached picture? because I don't think that part of my door is metal...I think it is real hard plastic and if you cleaned it with acetone it probably did wipe smooth.... Also I have seen spots on some cars (non A/C cars mostly) that are worn smooth because that it where the driver rests their arm
  11. M.A.V.
    M.A.V. Yep,my real initials.
    Macon,Georgia
    The part of the door highlighted in the pic is textured Steel.
  12. dmhines
    Cumming, GA
    Yup ... stick a magnet on it ... Mavericks are Metal ... (y)
  13. Mavaholic
    Could be when you wiped it, the softened paint filled in the grain.
  14. BOSSv10
    BOSSv10 Member
    Chicago, IL
    Yes, the part of the door I am talking about is where the white arrow is in the picture. I was thinking that it may have filled it in like Mavaholic said so I used a pick and tried to clean it. It did not work all that well. Gonna try some more reducer and soften it up some more and see what that does.
  15. Mavaholic
    I found a cup brush on a 4" grinder cleans that grain up real nice.
